Page 1 of 2 12 LastLast
Results 1 to 15 of 22
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Default w210 1d69j corrupt or no?
    hi,can anyone re-check this dump?
    w210 eis 210 545 02 08 q3
    lost keys.
    ive rad dump,load get pass made key. eis not unlock. tried diferent possitions, BE key ,vvdi BE ,ori nec key gen 3. all same,red led is on key,eis not unlock. when read eis again i see written key in new pos.
    Renault ECU tool / IO terminal / A.S.W
    Aug 2009
    maybe bad soldering or with hotair somthing destroy
    drugowaz's Avatar
    Mar 2015
    Lithuania
    But eeprom good?
    droidwayne65's Avatar
    Aug 2015
    North America
    Quote Originally Posted by drugowaz View Post
    lost keys.
    Test it on the bench with the VVDI ESL emulator. If it turns, good EIS, bad ESL. Oh, check all the flexible PCB connections; they have a tendency to come loose just enough to cause all sorts of silly problems.
  5. The Following User Says Thank You to droidwayne65 For This Useful Post:
    drugowaz (29th April, 2018)
  6. #5
    Mar 2013
    Europe
    You know, you have HASH error on 2 Key Position???
  7. #6
    drugowaz's Avatar
    Mar 2015
    Lithuania
    This error can cause key not turn?
  8. #7
    Aug 2015
    North America
    No. Take a look at what AK500 added keys do to a eeprom file, yet the keys work just fine. If the hash is valid, the mcu can calculate the correct checksum.
  9. The Following User Says Thank You to droidwayne65 For This Useful Post:
    drugowaz (27th April, 2018)
  10. #8
    drugowaz's Avatar
    Mar 2015
    Lithuania
    can anyone tell what component must be in marked red cirqle?
    it was there just soft like butter. dont have eis what to compare. found photos some kind of silver top. but not like capaccitor near him.
    bridge on legs removed.
    https://imgur.com/a/eyKYq8X
  11. #9
    Feb 2010
    In EEP
    30min I send you cleared foto
  12. #10
    drugowaz's Avatar
    Mar 2015
    Lithuania
    ok but good to know what componet is that. i got same eis from w210 on parts but on it that componet already removed. maybe on same eis i can find it in other place
  13. #11
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Check on esl 12v first one second - minus
    If you don't have voltage also can not turn lock newer
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  14. #12
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Im testing on bench with getaway. As now need to replace this component
  15. #13
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Found some pics
    https://mbworld.org/forums/clk-class...ding-them.html
    its for sure not cap like near him.
    Top is silver.
    Also its very soft not. On eis i cant see nothing similar like this component
  16. #14
    lion0304's Avatar
    Oct 2014
    This EZS when i work to remove MCU by hot air, alway need rework on all ribbon cable solder joint.
  17. #15
    drugowaz's Avatar
    Mar 2015
    Lithuania
    I readed it with adaptor. All joins recheked with multimeter. When put key. Red led is on.
