Results 1 to 8 of 8
    acam712's Avatar
    Mar 2016
    in the middle of the bulb
    Default Need correct checksum edc17
    Hello
    I need to correct CS in 2.0 tdi cr VW tiguan.
    mancioks's Avatar
    Feb 2017
    Germany
    Here you go.
    acam712's Avatar
    Mar 2016
    Mpps steel writing 75% and it is CS error.
    Any solution?
    sdtsedat's Avatar
    Jan 2015
    Belgium
    You have TPROT maybe, what is year of car?
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
    acam712's Avatar
    Mar 2016
    2008. Galletto show different CS in ori and mod file.
    mancioks's Avatar
    Feb 2017
    Germany
    Winols showed that in mod file cs was incorect, and corrected it.
    Tested it by my own CS for edc17 not one time and all was ok :/
    acam712's Avatar
    Mar 2016
    ok. but ori file is prog 100%ok. On ecu i have number 03L906022F, by obd show 03L997016J.
    Nov 2009
    EUROPE
    do not correct with winols write with galletto and let it to fix auto the cs.
