Results 1 to 12 of 12
    honingkoning's Avatar
    Jun 2010
    Dessert
    Default Vw polo 2015 TPC disable
    Guys is it possible to remove tpc in this model.
    This is the facelift type (with golf 7 dash)
    No error in car and tpc turns on every 3 days
    You reset it and after 3 days same story.
    Tire press is good, tires all the same.
    Wbr Adam.
    Btw i have gen vcds
    Jul 2016
    Vilnius
    So where's the autoscan?
    I can calculate ABS module codings for:
    * Continental/Teves MK60EC1 and MK60;
    * TRW systems in Passat B6 / B7 / CC /Tiguan;
    * MK100
    * Bosch ABS8.2, ABS9.0 and ESP8.2, ESP9.0;
    * EBC 460 (UP!, Mii, Rapid, CitiGo, Fabia, Toledo, etc) New!
    ... and other VW/Audi/Seat/Skoda modules.I can assist with repairing \/CDS interfaces.
    Jun 2010
    Dessert
    Quote Originally Posted by hid3 View Post
    You want a Total scan of the car with the error active?
    Wbr
    Jul 2016
    Vilnius
    Please do full car's Autoscan with VCDS and share it
    * MK100
    Jun 2010
    Dessert
    Here it is, i put long coding also (last row in the log)
    Wbr Adam
    would be very grateful for some solution.
    Jun 2010
    Dessert
    Some vag guru pls
    Jun 2010
    Dessert
    No one Guys?????
    Jul 2016
    Vilnius
    I think your best VAG guru is official dealer at this point... There is no documentation on that module, unfortunately
    * MK100
    Jun 2010
    Dessert
    brend's Avatar
    Oct 2015
    Same where
    This settings in abs modul.
    If you want this deactivate ,for this need first coding abs ,cangateway/dash (If istallation list have this)
    Better use for this genuine VCDS not china or high qulity Vas and last odis sw.
    NB!!! Don't ask in PM old file password , Im not remember.
  11. #11
    Jun 2010
    Dessert
    Quote Originally Posted by brend View Post
    If i pit coding from dash/abs/gateway can you help me?
    I have ori vcds So should be ok
    Wbr
  12. #12
    ghostrider72's Avatar
    Jul 2012
    UK
    Dash and gateway wont be a problem as you should have coding helper files
    Abs will problem be as there is no helper files for it. You can try to contact Ross Tech support for that one.
