try conect pin 1 and 16 on diagnostic soket to get diag.working
probably steereng lock faulty
I have problem with my mothers Audi Q5 80A 2.0 TFSI 252HP from 2018.
Auto is after colission has both right side doors (drivers side) crashed.
Front, right side and back are good.
We bought it crashed and want to repair and use.
But auto came to me with battery drained and at front cables were cuted(photo1):
i have soldered the cables and bought brand new agm battery.
But on auto works only MMi media player, climatronic, interior lights and tacho shows only for few second (audi q5 quatrro)Photo2 and 3.
Auto does not react on start stop pressing does not have ignition cannot read fault codes...;/;/;/;
auto has new pirotehnic security on 12V damaged but i bought new one and it still same.
On the VCDS and Autel i can only connect with CAN line and it shows only faults about connecting with drivers doors module, and with line assist module.
i cannot connect with other module or engine in my opionin beacouse of no ignition.
I chacked fuses on drivers side next door open and on back left side.
Where more are there any fuses?
I have no ide with this vehicle. exept cutted wires all other wires look good..
The second ground battery termina have also sam sensor, should i exchange also second battery terminal?
I tried to desactivate on VCDS transport mode but this does not work... I do not think that gues used diagnoskop to make transport mode but have chacked it also..
Where to look for issue?
Greets
Kuba
>>Genuine Winols, Swiftec, Ktag, Flex, x17<<
>Diagnostic, Chiptuning, Dashbord<
