Any suggestions?
Hi, my K+Dcan cable died. It is not cheap shit from ebay or aliex, it is from One stop electronics. It worked about 3 years, usb cable broke a few times, but i always solder it and it worked. Mostly broken shielding. Last time was broken shielding and ground. Repaired it, but when i connect it to pc, nothing happens, no new hardware. I checked some connection inside and i have 5V where it should be. There are Atmel Atmega162, ATF16V8B and FTDI ft232rl. Do you think it is worth replacing ft232rl?
I have ordered new cable. but i would like to know what is the problem.
Any suggestions?
Have u scoped to see if xtal is producing clock? Is switch working correctly?
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
Thanks for response, i am still waiting for scope, i will check that later. What switch do you mean?
My BMW one has a switch on it to go between K abd DCan. If yrs hasnt principle still same - see if click is present.
