Results 1 to 4 of 4
    Jan 2014
    Default mazda axela 2003 bk5p ecu
    hello again hope all well does anyone have a solution for this such ecu for a mazda axela 1.5i 2003 model ,,thus this model does not have an immo ,however im looking for the eeprom dump because my car starts but my speedo doesnt work and fault code p0612 ecu configuration error i did try using forsan to correct the error but unsuccessfull is it possible to repair my dump ecu part number 279721-2240 ,,,,,,,BK5P ecu thank you
    galaxy0634's Avatar
    Jan 2018
    Namek planet
    what is the cause who damage your eproom file
    Jan 2014
    vehicle came as non start the ecu was damaged and the alternator,, after fitting another ecu i swopped the eeproms and later found the eeprom corrupt ,,,the vehicle was tampered with previously but it doesnot have immo installed
    Jan 2014
    Problem solved ............. if anyone needs help PM regards
  5. The Following User Says Thank You to Mr Mo For This Useful Post:
    galaxy0634 (15th August, 2018)
