Results 1 to 11 of 11
    jodge's Avatar
    Mar 2017
    Default w124 1996 immo off
    The car is far away, it's just a pre check
    Possible to immo off this old modell? (one button IR remote DAS2)
    I don't have any info ecu type or anything else
    thx
    Sir, are you classified as human? Negative, I am a meat popsicle
    doctore's Avatar
    Nov 2015
    Colorado Denver
    maybe emulator its too old probably hc11 motorola inside ecu
    see pictures from ecu before you goo
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  3. The Following User Says Thank You to doctore For This Useful Post:
    jodge (14th August, 2018)
    jodge's Avatar
    Mar 2017
    can you check the pic?
    thx
    Shmortz's Avatar
    Apr 2010
    in the middle of nowhere
    yeah, it's possible and easy with Julie or OF68 emulator.
  6. The Following 2 Users Say Thank You to Shmortz For This Useful Post:
    HeXeN (3rd September, 2020), jodge (15th August, 2018)
  7. #5
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Yep its hc11 i tr to read with xprog and lift pin and nothing
    For this tipe ecu you need virgin file and mb star if you can read, emulator not work
    I tr many time and nothing
    And best chose give up from this only can have problems nothing more
  8. The Following User Says Thank You to doctore For This Useful Post:
  9. #6
    Shmortz's Avatar
    Apr 2010
    this must be ECU with one plug, here need to put only emulator and cut wires from green and red lamp or remove module.
    ...problems are with those with 4 or 5 plugs, I also tryed and succeded to make it virgin and personalise to other used immo, with emulators not working.
  10. The Following User Says Thank You to Shmortz For This Useful Post:
  11. #7
    jodge's Avatar
    Mar 2017
    @Scmortz did you tried julie? I saw in the supported list but who knows.. as doctore says
  12. #8
    jodge's Avatar
    Mar 2017
    yepp just one plug fixed with a philips screw
  13. #9
    Shmortz's Avatar
    Apr 2010
    I tryed on W202 with OF68 which is copy of Julie and working like a charm
  14. The Following User Says Thank You to Shmortz For This Useful Post:
  15. #10
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Quote Originally Posted by jodge View Post
    When you accept the this job, save the pill for the head
  16. #11
    jodge's Avatar
    Mar 2017
    deal
    thx
  17. The Following User Says Thank You to jodge For This Useful Post:
    doctore (15th August, 2018)
