Results 1 to 13 of 13
    Aug 2018
    Default 2006 W211 key doesn’t turn anymore
    Anybody know if OtoSys IM600 can do 2006 w211 Key progrmming? Original Key doesn’t respond anymore, not even buttons, no Hz signal out. Want to program another key, have EIS already out but don’t see function on IM600 for Mercedes key programming
    brend's Avatar
    Oct 2015
    Same where
    Maybe key PCB faulty!
    Take another donor key and replace NEC from original key.
    NB!!! Don't ask in PM old file password , Im not remember.
    Aug 2018
    Yes. I just wanted to know if I can use tool for Mercedez key programming if there is a situation with all keys lost. But I will replace NEC on this one to be done with it. Thank you.
    Aug 2018
    Quote Originally Posted by brend View Post
    Hi. I have a question for you, I’m sure you’ve run into this. Can’t find a good donor PCB identical as original, new style ones only, do you know how to transfer data from original to new style one since all the internal components are different?
    p1et's Avatar
    Oct 2013
    No need to be identical and plenty of those keys available from ebay etc.
    And for IM600 benz key programming they state it will be added soon but for this time not possible.
  6. The Following User Says Thank You to p1et For This Useful Post:
    Rastanova (16th October, 2018)
  7. #6
    Aug 2018
    So how do you transfer eeprom/data from one PCB to the other?
  8. #7
    Aug 2018
    Quote Originally Posted by p1et View Post
    IM600 tech support allowed to download Benz software but doesn’t work for this particular issue. I’m trying to solder NEC eeprom on good PCB but can you tell me how to store files form eeprom, I don’t know where to solder wires.
  9. #8
    brend's Avatar
    Oct 2015
    Same where
    Finde donor key remuve nec from original key and solder to donor ,thats all.
    If nec data ok ,its help!!!
    If key totaly bad,so....only new key calculating and programming.
  10. The Following User Says Thank You to brend For This Useful Post:
  11. #9
    Aug 2018
    I only have EIS I don’t have the car available can I calculate and program new key with just EIS?
  12. #10
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by Rastanova View Post
    With such questions I do not know why you took this kind of job...
    But yeah, EIS is enough...
  13. #11
    Aug 2018
    To learn
  14. #12
    brend's Avatar
    Oct 2015
    Same where
    Yes.
    And better if you have tools and test platform for this job.
  15. #13
    Aug 2018
    I think so. I buy equipment that promises to do it and then it doesn’t, tech support is not top notch if, it you know what I mean. So I’m forced seek info on forums and stuff.
