Results 1 to 11 of 11
    Jan 2018
    Default Need eeprom connection Bajaj pulser
    hello friends,
    Need eeprom isp connection Bajaj Pulser cluster to Upa-Usb programmer..
    it has glued lcd hard to dissemble it.
    here is it pictures ...
    Jan 2018
    Default Need adjust km
    hello friends,
    need to adjust 24LC01 original millage is 170,916km
    need 25000km
    zckariya70's Avatar
    Jan 2014
    Inside EEPROM
    Here, its direct km is algo, u can do it next time, look at the algo.....................
    Nothing will remain in this World , Everything will come to END!
    THINK POSITIVE NOTHING IS IMPOSSIBLE
    Please do not spam by PM asking for help. Use forum, that is why we are here.
  4. The Following User Says Thank You to zckariya70 For This Useful Post:
    sum444584 (22nd September, 2018)
    momogsm's Avatar
    Just Say Momo, I Will Be Here. ��
    Your File MOD
  6. The Following User Says Thank You to momogsm For This Useful Post:
  7. #5
    Jan 2018
    Default need adjust pulser 150
    hello fnds,
    bajaj 150 24LC 01B need 44,860km to 18,000km
  8. #6
    Sep 2009
    here is your file
    new.zip
  9. The Following User Says Thank You to nikz For This Useful Post:
    sum444584 (17th October, 2018)
  10. #7
    Jan 2018
    Default Hello friend,
    need to adjust this one, pulser 24LC01 78000km to 25000km
    thank you.
  11. #8
    Sep 2009
    here is your file
    new.zip
  12. The Following User Says Thank You to nikz For This Useful Post:
    sum444584 (19th October, 2018)
  13. #9
    Jan 2018
    thank you sir you always helpful..
  14. #10
    Jan 2018
    Default need correct 24c01 again
    hello masters,
    need to correct this 24c01 bajaj pulsar original 81000km and need 13000km
    thank you.
  15. #11
    zckariya70's Avatar
    Jan 2014
    Inside EEPROM
    Here.......................Ur orginal is not 81000, its 87114 changed as u requested
  16. The Following User Says Thank You to zckariya70 For This Useful Post:
    sum444584 (24th December, 2019)
