Results 1 to 5 of 5
    Jun 2017
    Pretoria, South Africa
    Default Land Rover Freelander 2 Smoking
    Good day friends
    I have an freelander 2 with white smoke from exhaust pipe, as I have diagnosed I saw the oil was dripping from the breather hose just after the air filter.
    Has anyone ever had this..
    Any help would be much appreciated
    Thank you
    Sent from my HUAWEI CAN-L01 using Tapatalk
    Jul 2013
    yorkshire
    If i am correct, these have a PCV on rocker cover. This can cause smoke and poor running.
  3. The Following User Says Thank You to autoden For This Useful Post:
    BraLaas (27th September, 2018)
    Jun 2017
    Quote Originally Posted by autoden View Post
    Ok friend oil burning sorted now.
    Another problem is under hard acceleration I have excessive black smoke from tail pipe. And an intermitted misfire..usally on idle with smoke from tail pipe..
    What was done before it came to me was
    - New injectors (Second hand)
    - New ECU
    - New Filters
    - New Turbo
    I have 2 DTC's as follows..
    P0380 - Glow plug Fault (Not to worried about this fault starting too easy when cold and engine smoking when warm aswell)
    P1402 - EGR Valve (I have blanked EGR Valve at front of engine next to intake as I saw when EGR is open/active, I get 0% which means fully open and when EGR is closed/not active I get 80% meaning the EGR is stuck open)
    What I have seen is that the injectors have not been coded, and when I try to code them operation fails..??
    Please guys help me as this is my buddy's car and he has been struggling for months now
    Jun 2017
    Quote Originally Posted by BraLaas View Post
    - New ECU
    - New Filters
    - New Turbo
    Engine and DTC's
  6. #5
    Meat-Head's Avatar
    If has maf sensor unplug
    Check map sensor not clogged, you might need bucket if swear words
