Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    omglol's Avatar
    Jan 2009
    Europe
    Default Audi A4 2000 need PIN
    Hello!
    I need pin for Audi A4 2000 1.8T. Dashboard is made by Magneti Marelli, attached dump from 5H55W (912DG128). Thanks in advance!
    Dec 2009
    code: 03528
  3. The Following User Says Thank You to exe123 For This Useful Post:
    omglol (25th September, 2018)
    omglol's Avatar
    Jan 2009
    Europe
    Quote Originally Posted by exe123 View Post
    code: 03528
    Thank you!
    I need to install new instrument cluster to this car. I have NEW instrument cluster, not used ... do I enter this as login code? Car has immobiliser generation 2. Thanks.
    Dec 2009
    Actually you just need the login from the new dash. not from the old one. these are not getting transfered on immo2
    http://wiki.ross-tech.com/wiki/index...ument_Cluster)
  6. #5
    omglol's Avatar
    Jan 2009
    Europe
    Hmm ... but how do I get login from the new dash? Dash in completely new, 0km, ordered from main dealer, it has never been installed in any car yet?
  7. #6
    Dec 2009
    Either by OBD or via dump. Actually dealer can pull the login via the immo-ID but he is not able to give you the login. Odis will login automatically for adaption of keys
  8. #7
    omglol's Avatar
    Jan 2009
    Europe
    I see. Too bad VAG EEPROM programmer does not read this dashboard. Looks like I will have to open it.
    So when you adapt keys to the new dashboard you use new PIN? You can keep old transponders inside keys? Thanks.
  9. #8
    Dec 2009
    Yes, immo2 keys can be reused. Immo3 gets locked while learning.
  10. #9
    omglol's Avatar
    Jan 2009
    Europe
    Thanks!
    Could you give me PIN from this new dashboard? Thanks!
  11. #10
    Jul 2016
    Poland Alkoholand
    i have always reused keys in immo3 , no problems
  12. #11
    omglol's Avatar
    Jan 2009
    Europe
    Quote Originally Posted by bendzji View Post
    Cool. Do you know how to get pincode from the dump above maybe?
  13. #12
    Jul 2016
    Poland Alkoholand
    Sorry cant help , I always throw out the jeager clusters and adapt vdo
  14. #13
    omglol's Avatar
    Jan 2009
    Europe
    Thanks anyway, maybe somebody else will be able to help.
  15. #14
    Dec 2009
    Immo3 key can be reused as long you have at least dash or ecu synced with the keys.
    Your login for new cluster is : 01869
  16. The Following User Says Thank You to exe123 For This Useful Post:
    omglol (26th September, 2018)
  17. #15
    omglol's Avatar
    Jan 2009
    Europe
    Thanks for the pin.
    By the way, should anyone need, above dump is from 8D0920900T brand new instrument cluster (virgin dump) from 4K91D (that's right, 4K91D, not 3K91D ... but they are the same).
