Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: w166 2016 fbs4
    diagtech2000's Avatar
    Jul 2013
    North of England
    Default w166 2016 fbs4
    hello, im stuck with a car of my own, i think i have a faulty key/eis on my w166 gle 2016,
    does anyone on here’s know of anybody out there that can test/repair my key/eis ?
    it did work fine (ignition lights all on etc) but now ive got nothing and i think the key is faulty. u can see from pic below where the actual plastic (blade) meets the body of the key it’s coming apart.
    any help on this would be much appreciated
    Please hit thanks if this helped you!
    Top Poster dooshan's Avatar
    Mar 2012
    Belgrade
    Try to repair it. New housing. At the and,find another/new and swap processor.
    p1et's Avatar
    Oct 2013
    And it got destroyed like that just by yourself i 2 years?? Wtf.
    If yes, do like said above, get a new case and swap electronic board
    Jul 2013
    North of England
    no its been in a crash and drivers knee damaged key (i think)
    but it worked the other day (all ignition lights on) but i think the pressure on key after a few ignition cycles has caused the connections to come apart apart on the key maybe,
    as you can see from picture the actual body of the key is slightly loose(coming apart from blade)
    is it possible the just swap internals of key (board etc) ?
    Mar 2012
    Belgrade
    Board is broken. Or coil at the best. Opet it. Slice it in half and u’ll c what you need to do there.
  6. The Following User Says Thank You to dooshan For This Useful Post:
    diagtech2000 (14th October, 2018)
  7. #6
    pepi's Avatar
    Jan 2010
    If coil is ok needs reballing of two BGA chips .
    Sent from my SM-G925F using Tapatalk
  8. The Following User Says Thank You to pepi For This Useful Post:
  9. #7
    Jul 2013
    North of England
    coil broken
  10. #8
    Jul 2013
    North of England
    can these just be swapped from another working key?
  11. #9
    newone's Avatar
    Oct 2016
    yes,change coil for start and test if it works.
  12. The Following User Says Thank You to newone For This Useful Post:
  13. #10
    Jul 2013
    North of England
    changed coil still no luck,
    what you guys think next ? (bga swap?)
  14. #11
    Mar 2012
    Belgrade
    Quote Originally Posted by dooshan View Post
    Find used key,swap bga.
  15. The Following User Says Thank You to dooshan For This Useful Post:
    diagtech2000 (15th October, 2018)
  16. #12
    Jul 2013
    North of England
    yes that’s what im going to have to try i think, these micro bga chips dont look easy to swap ,
    i do have a friend who is very good at soldering/rework etc, even he is telling me if the micro bga has more than 16 balls it will not be straight forward at all to swap!
    is there any specialists out there who can confidently do this for me? ill pay £ of course ?
  17. #13
    lpf01's Avatar
    Oct 2013
    Quote Originally Posted by diagtech2000 View Post
    There is a BGA reball stencil for this chip on the market, i personally bought it but never used, if you are struggling with it send a pm and we will figure out something....
    Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
  18. The Following User Says Thank You to lpf01 For This Useful Post:
    diagtech2000 (16th October, 2018)
  19. #14
    Jul 2013
    North of England
    thanks ill pm you if i need your help
  20. #15
    lion0304's Avatar
    Oct 2014
    I've made BGA rework longtime ago, for this key, it's easy for me. I never use stencil because it so small and not easy.
    I put balls by hand 0.45mm in 10mn. 3mn to smelting. The most important is desolder and resolder to work.
    Yes, you need someone who usual work with BGA, or you can detroy BGA and PCB.
  21. The Following 4 Users Say Thank You to lion0304 For This Useful Post:
    bersch8688 (22nd October, 2018), diagtech2000 (16th October, 2018), doctore (16th October, 2018), TeL200 (27th October, 2018)
