Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Feb 2018
    Default Peugeot 206 BSI problem - 9646777380 vs 9645747490
    Hello,
    I have a big problem
    I have 2 BSI.
    1. BAD BSI - from 206 1.9D 9645747490 (attachment file)
    2. NEW BSI - from 206 1.6 16V NFU 9646777380
    I changed from BSI 1 EEPROM 95160 to BSI 2, but the vehicle does not start, PP2000 does not see the VIN
    Where problem? I must virgin for new BSI?
    gege974's Avatar
    Oct 2018
    réunion island
    we must all recode with diagbox.
    Small circumstances produce great events : 02.47-tranquillité:
    Feb 2018
    ok, do i need a virgin BSI?
    Dec 2009
    Yes, you do need.
    Feb 2018
    can i ask for the virgin from the attachment above?
    May 2014
    This is your file.
    pin code: UKA7.
    remember the buttons.
  7. The Following User Says Thank You to alefabi2006 For This Useful Post:
    ChouLu (15th October, 2018)
  8. #7
    kiszka's Avatar
    Aug 2009
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
  9. The Following User Says Thank You to kiszka For This Useful Post:
    galaxy0634 (15th October, 2018)
  10. #8
    Feb 2018
    I'm confused ? UKA7 or OKDJ?
    Apologize for my ignorance, but ...
    This file is from bad BSI. Can I copy it to a new BSI and then set it through PP2000?
    Or do I need a file from the new BSI and make it a virgin?
  11. #9
    kiszka's Avatar
    Aug 2009
    Reality of life :
    3:Everyone lies
  12. #10
    May 2014
    Friend I feel my mistake.
    UKA7 is incorrect.however my calculations say correct pin is: DJYXvin: VF32AWJYF2025301
    Friend I feel my mistake.UKA7 is incorrect.however my calculations say correct pin is: DJYXvin: VF32AWJYF2025301
  13. The Following User Says Thank You to alefabi2006 For This Useful Post:
  14. #11
    May 2014
    Puedes comprobar si estoy equivocado.
    friend kiszka
  15. #12
    kiszka's Avatar
    Aug 2009
    Reality of life :
    3:Everyone lies
  16. The Following 2 Users Say Thank You to kiszka For This Useful Post:
    Abdo Abdelatif (15th October, 2018), ChouLu (15th October, 2018)
  17. #13
    May 2014
    ECU file say what is the correct
  18. #14
    Feb 2018
    Yes, VF32AWJYF42025301 is correct
    so the pin is OKDJ Thanks
    if you do not have the original BSI eeprom
    you must read the eeprom ecu to recover
    original pin
    File in attachment in first post is from original BSI.
    Thank you very much, I will try all this weekend
  19. #15
    lion0304's Avatar
    Oct 2014
    When you swap only eeprom to doner BSI, car will see BSI virgin.
    Just use pin and recode. Tested many time
