Results 1 to 9 of 9
    Aug 2018
    Default PSA Peugeot 308 1.6 90bhp kess/mpps?
    I was wondering about remapping this car:
    MPPS INFO: (read write only in the car) leave key off for at least 3 min after prog)
    KESS INFO: On some types of ECU it need to be needed to recode the encoding of the injectors through a diagnosis tester.
    We recommend not turning on the engine after programming and wait till dash completely off.
    Any more info?
    Can we disable this in the MAP?
    ivanmihov's Avatar
    Nov 2016
    Europe
    for this use it's better not to risk,you need to open it and read/write in bdm with ktag
    Aug 2018
    Quote Originally Posted by ivanmihov View Post
    Thx.
    Is there a list (KESS/MPPS) for cars that you should not do using OBD?
    May 2018
    Kess read and write this without problem by Obd.
    After write you must wait 3 min with ignition off and 2 min with ignition on then car start.
    Wysłane z mojego SM-G965F przy użyciu Tapatalka
    moky's Avatar
    Apr 2010
    Behind you
    kess and mpps work fine on edc16C34 if you respect procedure,tested.
    Myjector's Avatar
    Dec 2017
    Kess works fine, and write very fast to, faster than X17
    But if you feel not safe, take a bdm full read first.
    Cut off ignition for about 3 minutes.
    AUTOTUNER, FLEX ,X17, TRASDATA / NEW GENUIS AND ALIENTECH MASTER OWNER.
    FULL SWIFTEC AND EVC RESELLER
    FILE SERVICE FROM 8AM - 9PM 7/7
    BAPRO 4WD DYNO
    Aug 2018
    its EDC17C10 / 60...
    Kess says its normal OBD
    Myjector's Avatar
    Dec 2017
    Only Autotuner does them OBD.
    But if you have an ktag clone you can do EDC17C10 in boot, easy connection
    BAPRO 4WD DYNO
    Aug 2018
    Quote Originally Posted by Myjector View Post
    i don't but i might buy one then because it's quite annoying to tell people you can't do something.
    Just because you don't have the stuff for it.
    How long do you guys tell people it would take?
