Results 1 to 2 of 2
Thread: Original file
    Nov 2018
    Default Original file 8E0909518AQ
    Hello. my friend have a problem. b7 bfb motor ecu don`t answer no hardware id find so if anybody have original software 8E0909518AQ
    what i can use i have kess v2 so i want to try if i can wrote that ecu and help my friend. and what file type kess v2 use? never use that kess v2 yet
    best regards
    Janne
    Dec 2018
    8E0909518AQ 163 Audi A4
    HW: 0261208524
    SW: 1037372505
    Original no Pass, dont forget thanks .
    Also if using kess try changing the PULL UP and use a stable battery source
  3. The Following User Says Thank You to MVRH For This Useful Post:
    longgo (4th May, 2020)
