Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
  1. #16
    immokill's Avatar
    Jun 2009
    UNIVERSE
    2010 PSA van with fiord injection SID208. . I heard that it must be over 13 V. powe suply and it will work with clone Ktag red pcb .
    Here to HELP!
  2. #17
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Yes it will13.5v 3amp min
    Ktab obd cable
    144300T108 pinout :
    KTAG_DB15 ---> OBDII
    11 ------------> 04 ; 05 (Ground)
    07 ------------> 06 (CAN_H)
    14 ------------> 07 (K-Line)
    15 ------------> 14 (CAN_L)
    05 ------------> 16 (Battery Power)
    I've not tried this cable though
  3. The Following User Says Thank You to teerak2uk For This Useful Post:
    immokill (13th November, 2018)
  4. #18
    immokill's Avatar
    Jun 2009
    UNIVERSE
    I will take a chance to do with ktqg clone pcb via boot mode .
    rhanks
    Here to HELP!
  5. #19
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by immokill View Post
    rhanks
    Will be fine PSA but after 2013 will struggle prt change's
  6. The Following User Says Thank You to teerak2uk For This Useful Post:
  7. #20
    Sep 2016
    Poland
    obd protocol have only genuine, china shit have only boot read
    FILE SERVICE
  8. #21
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Magic did it by obd so problem solved friend did it with latest magicpro
    Here to HELP!
  9. The Following User Says Thank You to immokill For This Useful Post:
    teerak2uk (14th November, 2018)
  10. #22
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Solved and ktag diidnt id it wirh 14v 5amp power . I measured on cables on bench on orange cable i uave 12.6max why if I puted main ktag power to 14v ?
    Here to HELP!
  11. #23
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Maybe your clone needs rework
  12. The Following User Says Thank You to teerak2uk For This Useful Post:
    immokill (17th November, 2018)
  13. #24
    immokill's Avatar
    Jun 2009
    UNIVERSE
    I t is red pcb reworked . Read edc17 good read bmw good vag med17 . Thanks for info i will take aprt and look where is my 14v going to....
    Is there any picture what to rework and what is usualy problem on ktag power suply?
    Here to HELP!
  14. #25
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Did you try to power ECU direct?
    Also not sure if 5amp is enough the supply I use is 15-20amp
  15. The Following User Says Thank You to teerak2uk For This Useful Post:
  16. #26
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Default CITROEN JUMPER 22HDI SID208
    Quote Originally Posted by teerak2uk View Post
    15 20 A ??????
    Power ecu direct and put can high low and not powe on ktag?
    Sent from my TELEFON
    Here to HELP!
  17. #27
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    15 20 A ??????
    My psu supplies upto 20amp
    Yes power at ECU can hi/low via ktag
  18. The Following User Says Thank You to teerak2uk For This Useful Post:
  19. #28
    Mar 2013
    Europe
    Use Power direct to ECU -> 12V & GND to the ECU Pin's and Can HI & Can LO from Ktag
  20. #29
    carmageddon's Avatar
    Apr 2010
    Italy
    i did many sid 208 ford but i used always supply 12V 2A!
  21. #30
    macako6's Avatar
    Mar 2015
    Forget the cloned tools for this ecu, it does not work, clone Ktag on this ecu. Ktag genuine this ECU (SID208) works through the OBD without any problem.
    Only information is already available, and Ktag genuine can sometimes make a problem and report an error (no communication).
    But when everything is repeated (re-read) the operation then passes and there is no problem, I do not know why this is happening.
    I use a voltage regulator of 14V and 5A.
    For this problem, I have contacted Alientech and their response is "Change the voltage regulator" power supply.
