Results 1 to 4 of 4
    Oct 2013
    Default peugeot 208 airbag problem
    good morning i have a problem with an airbag ecu from peugeot 208 bosch 0285012924 , inside i find aN 95320 eeprom i clear it out and the the warning lamp not clear ,the fault i have read after the clear off file is B1401 STEERING TYPE CONFIG FAULT , can you help me ?
    Le-Mans's Avatar
    Jun 2017
    Compare with this working solution pass in pm after thanks and rep
    Jul 2012
    Netherlands
    It is probably RHD module in the LHD auto. You should be able to correct it with the Peugeot Planet
  4. The Following User Says Thank You to massiwe For This Useful Post:
    Le-Mans (16th November, 2018)
    Sep 2020
    Default peugeot 208 crash reset
    Hello everyone,
    Anyone can clear a crash data from a Peugeot 208
    Got a clear but get B1401 steering fault config.
