Page 347 of 851 FirstFirst ... 247297337342343344345346347348349350351352357397447847 ... LastLast
Results 5,191 to 5,205 of 12762
  1. #5191
    May 2017
    I have cabel on chip BL and looks working ok. But with now one problem. I can not connected to Audi A4 2013 to Parking Assist also on channel 10 and 76.
    CABEL ON CHIP FT232BL not working correct with all cars. With some work ok.
  2. #5192
    May 2010
    Poland
    pepeEL, this A4 can have PDC module build-in BCM1 give me coding of 09 module in PM
  3. The Following User Says Thank You to 1 6 D For This Useful Post:
    pepeEL (1st September, 2017)
  4. #5193
    May 2017
    This car is my friend. Now i can not read it.
    PDC in this car is in module 09 in VCDS ? And what is BCM1 ?
  5. #5194
    Aug 2009
    Quote Originally Posted by liviudiaconu View Post
    Is 44 with BM/BL.
    Kolimer affirm V2 work on BM/BL too. Some persons affirm not work.
    You will try and will see.
    In my case it does not work.
  6. #5195
    May 2017
    For me on BL works ok.
  7. #5196
    Oct 2008
    SLO
    Work on my old BM cable.
  8. #5197
    xoom's Avatar
    Dec 2009
    Ylakiai
    Tryed to read fault codes or do SRI reset? or just pressed test in Options window?
  9. #5198
    May 2017
    Read and clear fault codes for me works ok and also TEST in option windows also is OK
  10. #5199
    xoom's Avatar
    Dec 2009
    Ylakiai
    Played a bit more.. tryed to change PID but same results
  11. #5200
    May 2017
    Quote Originally Posted by eliotroyano View Post
    Quote Originally Posted by xoom View Post
    Hi all
    NEWS NEWS NEWS
    I test my cabel HW 0x44 on chip FT232BL on other car. I test on VW Tiguan 2008. Not working correct. When read fault codes it generate in this cars in all modules more and more errors(fault codes) and cars not working correct and enginee go to any emergency mode.
    KOLIMER i confirm that cabel on FT232BL not working FULL with all cars. But with my Seat Exeo 2010 works ok and no generate errors and fault codes. But on Tiguan 2008 not working correct.
    Please help us.
    I have a question
    If i have FT2323BL i can only desolder and replace it with FT232RL ? Or any electronicals i also must change if i want change FT232BL ?
    Because i think to change on my cabel only chip FT232BL to FT2323RL and after that maybe cabel start working correct with all cars.
    I buy my cabel with version 11.11.5 EN and PL and in previus it working ok. But now i dont have epprom and flash to go back. Anybody has ? and can share it.
    Fantomel please give me link to your mega becuase i see on other forum that you have any other dumps...
  12. #5201
    May 2016
    Kaunas
    Quote Originally Posted by pepeEL View Post
    Hi all
    How do you want to change completely different microchips? If you really want - you can do this, but is it worth it?
  13. #5202
    May 2010
    Hi , i have a question about new china clone.Which of these interface can be programmable ? I need buy smt, but these PCB looks different.
    1. https://www.aliexpress.com/item/10pc...830906052.html
    2. https://www.aliexpress.com/item/10PC...832331129.html
  14. #5203
    xoom's Avatar
    Dec 2009
    Ylakiai
    Quote Originally Posted by szantis View Post
    First one.. with ATmega162
  15. #5204
    May 2017
    Quote Originally Posted by vaicekas View Post
    You have right
    But Kolimer this not working correct on chip BL. Works on some cars but on some not working and generate in car modules more and more errors(fault codes)
  16. #5205
    May 2010
    Poland
    Maybe stay with 17.1.3 if 17.8.0 makes problems
