Page 44 of 127 FirstFirst ... 3439404142434445464748495494 ... LastLast
Results 646 to 660 of 1900
  1. #646
    Oct 2017
    Quote Originally Posted by madaxe View Post
    rob h: I only use good quality USB cables, that work with Tango, which is the most fussy USB device I have. Virus scan does not run by itself, only 1nce a month, of if I sense a problem. I am admin priv on all locksmithing PC's. Only got USB3 ports and powered USB3 Anker Hub in my setup, which has never failed even with Tango. None of which would explain why it worked well enough to update the XC-mini, which took 20 mins. Then stopped after the XC-mini software update :-)
    XHorsesupport: I got your PM and will contact you on Monday when I know your timezone. But looks to me like the PC is contacting the XC-mini, and starting the connection, because the XC-mini screen resets and changes colour. Do you have a specific driver you want me to try ?
    Also, is it possible to have a screen testing / alignment function put into the XC-mini ? Some of screen buttons are so small, and dont seem to line up very well, worse case for me is putting the bitting in manually for a HU64-2. The '1' button when I press it clicks the return to main menu button. Most other keys are fine because I can use Instacode Live, but cant see how to get Instacode Live to use HU64-2. A stylus would be good if you can say what sort will work, but I think the alignment function needs to be there too.
    Also, noticed a problem trying to cut TOY43 emergency blade for Prius (pic attached). The plastic part wont fit in the clamp to line the tip up. And if I clamp the metal part, the machine wont cut it becuse the tip doenst align.
    Also, shoulder aligned keys arent very accurately cut, because the shoulder is aligned by eye. It would be better if the shoulder were 'discovered' using something like the universal copy function (lots of small movements to find the change in width of blade). I had a (Silca) GT15R the other day where the shoulder was aligned correctly, or so I thought, but the cutter took the tip of the key off when it moved around to cut side 2.
    Still very happy with the machine, but getting rid of the small bugs will make it an even better machine.
    have an extra drive for a try,but I think there is a lot other things to check,I have given to you my contact,can check remotely for you.add my contact.
    screen buttons click not accurate,it's the static affect the touch,please avoid this.I have given to you the details in PM.
    about the toy43,please use the black metal in package to assist(put on the shoulder)
  2. #647
    Greece
    4.0.2 and 4.0.3 fo21 key not work ok. i have also speak with tech support for this. i return with old tool to 4.0.1 and fo21 cut ok but now 4.0.1 only on chinese language.
  3. #648
    Greece
    the bid is 412123
  4. #649
    Oct 2016
    Scotland
    Quote Originally Posted by kleidaras View Post
    the bid is 412123
    Must be that the cutter moving across too high. I wonder if doing a calibration or something will solve this problem with those versions.
    My machine still on V4.0.1, I've never made time yet to do upgrade and wasn't much feedback from others that i seen.
  5. #650
    Greece
    i try calibration and not help. also i downgrade on 4.0.1 with old update tool and cut it ok. the problem is 4.0.1 now is only on chinese language
  6. #651
    Jul 2015
    I also have problem with FO21 using v4.0.2
  7. The Following User Says Thank You to gokart For This Useful Post:
    kleidaras (11th January, 2018)
  8. #652
    Jan 2017
    USA ����
    Same problem with fo21 tibbe key
    I wonder what the changes in 4.0.3 were.........
  9. #653
    ghostrider72's Avatar
    Jul 2012
    UK
    Hi guys
    I already have few tools for immo programming so I just thought i could add cutting as a option.
    So question is to the Condor Mini users - would you recommend it as a first cutter?
    Will be used mostly on VAG cars.
  10. #654
    wissamshaat's Avatar
    Oct 2017
    france
    its my first tool to cut keys and i recommend it
    verry good tool
  11. #655
    Maartinj's Avatar
    Nov 2010
    soon Xhorse add new M4 clamp for home keys
  12. The Following User Says Thank You to Maartinj For This Useful Post:
    WRX 14 (13th January, 2018)
  13. #656
    Feb 2014
    Quote Originally Posted by Maartinj View Post
    Any details on the coverage? Single sided or dimple? And what brands will be supported?
  14. #657
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by autoTkey View Post
    just seen a sample of M4 clamp
    hard to say if this is a official version or one of "sample"
  15. #658
    Moderator
    PremierD's Avatar
    Jun 2009
    looks a bit like this ...
  16. The Following 2 Users Say Thank You to PremierD For This Useful Post:
    AndyCZ (13th January, 2018), Samic (13th January, 2018)
  17. #659
    Oct 2017
    Quote Originally Posted by sleepyrz View Post
    we are checking this problem,soon give a solution
  18. The Following User Says Thank You to Xhorsesupport For This Useful Post:
    kleidaras (13th January, 2018)
  19. #660
    Jan 2017
    USA ����
    Another clamp for single sided home/ car keys would enable the machine to do some keys it currently cannot
    Chevy 6 cut single
    Vats keys single and double
    A ton of house keys
