Results 1 to 10 of 10
    Feb 2010
    netherlands
    Default RB4 8e0920930r vin problem
    So i tryed a lot, erase dtc, recode vin numbers in several modules.
    But problem came back. So i did a lot of reading and i found the problem is in the kombi.
    So i checked the vin in the combi and YES there the problem is.
    But the question now is:
    Can i update the kombi, with an update or other software update? there are company's in germany that do this.
    my version is rb4 d37.
    see attached log and screen shot from vcds.
    br johnny
    Dec 2009
    read dump from dash and rewrite vin into dump.
    there is an updated firmware but you cannot update the dash. also audi has no update for it. they replace the dash if it has this problem
    Feb 2010
    netherlands
    ok thanks for this, now im looking for tool:
    i see that k+can some people use for this, ive seen it at ecutool.com
    is this good tool for this?
    VAG DASH COM+CAN
    ore better to buy:
    4-IN-1 VAG TOOL KIT
    and ive seen at original com + can cost 1000 euro, maybe better to leave the clone and take this?
    another thanks!!
    Jul 2017
    I have the same problem with my color tacho
    I want to swap from red to color, i have the pin of red, the pin of color, set mode 4 to color but i cant change in vcds the vin (i try rosstech auto learn procedure)
    How you have solved?
    I can write the vin direct in vag programmer?
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by sjonv View Post
    br johnny
    Put kluster damp here.I check this and try modify vin by this or virgin .I have any sulution for RB4.
    Jul 2017
    Quote Originally Posted by brend View Post
    i have dump old red and new color dash, if you can help me
    Jan 2010
    I think vageprom can do this dash ok
    Jul 2017
    I have vag eprom i dump with it
    Jul 2017
    i can modify the dump of the color cluster with the data of the red? i mean vin and the other code and them write to the color with vag eprom or i need to calculate the checksum?
    Jul 2017
    i have put vin and immoid on color cluster but i need also to put pin of the old cluster, i try to adapt key but dont works
