So are games now working of a USB hard drive?
Well that first sysCheck you have 10 IOS's that are Stub but you have installed IOS 12, 13, 14, 15 I don't know how. You need to remove IOS 11, 20, 30, 50 install 40.
You do have IOS36 and IOS236 that's all but you need to reduce that 10 down to 4 or 5.
Download
ModMii6.3.1 and run ModMii.exe from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
ModMii only installed 2 d2x v8.0 wads download
d2x v8 Final wad pack and put these in the wad folder on the SD card, install all 7 wads when you install the other wads.
Put the SD card back in the Wii and run Homebrew. You already have IOS236 but it won't hurt to install it again. Run IOS236 Installer v5 Mod first before you install any other wads. Multi Mod Manager (MMM) should be the first app listed select it and load it. Once running scroll down to WAD Manager and press 'A' that will default to all wads in the wad folder. If you want to install all wads shown just press 1 that will list all wads you want to install press 'A' again to install them all.
Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
Download
PriiLoader 0.7 add it to the SD card and run it from Homebrew and set it to block online and disc updates, you can turn off the 'A' safety prompt on startup I do.
If you have to update to 4.3 then the Shopping Channel may not work. If it doesn't without doing another system update don't bother just install my
RVL-Shopping-21
Do another sysCheck to make sure everything installed correctly and post that.
Then you just have a to find a compatible mains powered USB hard drive to add your games onto and download USB Loader GX 3.0 to run them.
