Hello Friends
I need a cal file for Cummins ISBe CM800.
Engine SN: 21624342
Calibration software phase: 01050805
Calibration time date stamp: 102904103506
DO option: 09335
ECM code:T90098.08
SC option: 97161
The ecm displayed active code 111, but after I removed from engine and did a bench hookup there was no 111 code present.It was also throwing codes for all four injectors - current below normal or open circuit but these als dissapered.
It did not retain the codes as inactive but completely disappeared.
When I reinstalled it on the engine and I hooked up to insite the codes were not ther but as soon as I engaged the started to turn the engine the codes 111 and the ones for the injectors became active again
I am thinking of reflashing the ECM with a cal file, is this the right approach.
Thanks, appreciate some help
ramianek (12th June, 2019)
Still need some help
When you attempt to start engine, the 111 code becomes active. After you turn ignition off and turn it back on there is no 111 code. Attempt to engage starter again 111 code is there and engine will not start.
Tried another ECM and same probelm, I used the ecm on another engine and engine starts without probelms.
Engine mounted in DAF LF45
Your suggestions are appreciated
It's not something as simple as a weak battery? I've spent many hours trying to diagnose strange error codes on a couple engines and all it took was a battery charger.
Any answers from the experts, I am going to make a next try on Monday.
Should anyone have any suggestions please post
mathura, have you tried just connecting bench harness,
along with engine & actuator ports to see if your engine
would start? may have interferance from another module.
Have you reflashed the ECM?? and if you did what was the result.
We?ve had a problem here at our HD Cummins Repair Shop and most of the time when there is an 111 active code... the ECM must be replaced.
Now you say you tried another ECM and the problem persists, but is the same code comes active in that other ECM?
That code is only activated when there is an ECM internal harware failure man.
M8, I just hope that you get that engine up and running.
The Ecm that is throwing the 111 code was installed on another engine and it started the engine and worked fine, no peobelms, no codes.
I used another ECM from a known working engine, and the 111 code is recorded on this ECM also.
Today I used a break out harness on the OEM connection and power the ECM, as soon as I tried to start the engine the 111 code appears.
It now seems as though the probelm is existing with the engine harness.
Still looking for help on this one
isbe diagrams
isbe diagram, not able to veiw as complete diagram.
I think that I have made some progress but not 100% sure until tomorrow I will be able to confirm this, I am awaiting injectors to confirm my results
All four injector coils are reading infinity(open circuit)
Has anyone had this situation before
