Page 1 of 2 12 LastLast
Results 1 to 15 of 28
    xanubysx's Avatar
    Sep 2010
    EUROPE
    Default Need IMMO OFF IAW 59F.M2 hw 002 \ 1702 - MFL
    Hi guy, i read flash from Fiat Punto 1.2 for help Marelli Decoder ... and need 100% immo off file... orig post down ... or you can edit the file reliably by a program? For example, immo decoder 3.2?
    Thank you for help
    Number ecu:
    IAW 59F.M2
    IAW 59F.M2 hw 002 1702 - MFL
    267 99
    61600.389.04
    B671
    46760606
    1702-MFL.ZIP
    Do not forget to THANKS !
    SWIFTECH FULL
    ECM Titanium FULL
    KESS V3
    AUTOTUNERS
    B-FLASH
    WINOLS
    TOPDONE
    AUTEL
    FILE SERVISE .. web under construction
    xanubysx's Avatar
    Sep 2010
    EUROPE
    Resolved.. car is now ok immo OFF
    SWIFTECH FULL
    ECM Titanium FULL
    KESS V3
    AUTOTUNERS
    B-FLASH
    WINOLS
    TOPDONE
    AUTEL
    xanubysx's Avatar
    Sep 2010
    EUROPE
    Default immo
    Problem solved, now is ok . . .
    SWIFTECH FULL
    ECM Titanium FULL
    KESS V3
    AUTOTUNERS
    B-FLASH
    WINOLS
    TOPDONE
    AUTEL
  4. The Following User Says Thank You to xanubysx For This Useful Post:
    taxi300 (16th May, 2013)
    Jul 2010
    hi please can you help me i need immo off for my car fiat punto 1.2 YEAR 2001 ECU MM IAW 59F
    THANKS
  6. #5
    xanubysx's Avatar
    Sep 2010
    EUROPE
    Post your file
    SWIFTECH FULL
    ECM Titanium FULL
    KESS V3
    AUTOTUNERS
    B-FLASH
    WINOLS
    TOPDONE
    AUTEL
  7. #6
    aslamaslam's Avatar
    Feb 2012
    FRANCE
    hi
    can you help me i need immo off for fiat punto 1.2 ECU MM IAW 59F
    and what the device use for this pls
    thenks
  8. #7
    xanubysx's Avatar
    Sep 2010
    EUROPE
    I use IAW Decoder ... you use KWP to read.. and post orig file ...
    SWIFTECH FULL
    ECM Titanium FULL
    KESS V3
    AUTOTUNERS
    B-FLASH
    WINOLS
    TOPDONE
    AUTEL
  9. #8
    Jan 2010
    EU
    Quote Originally Posted by xanubysx View Post
    Can you help me with immo off ? Ecu is IAW59F HW002. I have read with Mpps v12. In attach ori file, I hope it is good read.
  10. #9
    Dec 2015
    HI! Can you help me with immo off ? Ecu is IAW59F HW002.
  11. #10
    Mar 2010
    Dupnitza, Bulgaria
    Here you are...
  12. #11
    Jun 2014
  13. #12
    Jun 2012
    HI! Can you help me with immo off? Ecu is IAW59F HW002 1702-MFL.
  14. #13
    kumbari's Avatar
    Aug 2009
    Germany
    Default Fiat punto iaw59fhw002 need immo off
    Fiat punto iaw59f hw002.1702-mfl need immo off
  15. The Following User Says Thank You to kumbari For This Useful Post:
    LabraxDz (9th August, 2019)
  16. #14
    Jan 2016
    Hi mates
    my ori key are broken, can I used key from scrapyard program in to BSI ??
    I can get pincode
    I dont have new transponder to make new key
    car Punto 1.2 8v Y2000 BSI Delphi ecu IAW 59F.M2 hw 002 \ 1702 - MFL
  17. #15
    Nov 2009
    pls i need immo off i read with fgtechv54 iaw59f.bp
