Page 1 of 6 123456 LastLast
Results 1 to 15 of 85
    fruti's Avatar
    Dec 2009
    Default Golf 7 Johnson Control need mileage change
    Hello guys,
    does anyone know an algo for Golf 7.
    Inside is now 18710km .... I need 20357km
    Regards
    Sep 2009
    There is no possibility of correction in this car by chip or by obd at present
    Don't forget to hit thanks button
  3. The Following User Says Thank You to javyb For This Useful Post:
    odog (26th December, 2017)
    fruti's Avatar
    Dec 2009
    i need solution only for chip ... i already have solutin for nec ... i need only algo for mileage in eeprom
    smartymarti's Avatar
    Jan 2011
    cornwall
    would you like to share with the world something we all dont ???
    All about the Bass
  6. The Following User Says Thank You to smartymarti For This Useful Post:
    dave11674 (15th April, 2015)
  7. #5
    fruti's Avatar
    Dec 2009
    I'm sorry .... i own an explanation. I didn't have time yesturday
    Costumer want back mileage. I copy eeprom when car had only 18k km .... Now have around 40k.
    When i copy eeprom back everything worked fine until dash went to sleep. Then Nec and eeprom sync and next time you start car ... old mileage is on it.
    So i make some experimental modification on dash and disable sync nec and eeprom. But, problem is ... costumer want 20k on dash ... that why im asking for algo....
    But i guess it is crypto and noone decrypt and calculate algo yet
    So we wait
    Regards
  8. The Following User Says Thank You to fruti For This Useful Post:
    clearly (21st August, 2017)
  9. #6
    Oct 2010
    Smellcom are promising this model the last 18 months and still no success
  10. The Following User Says Thank You to paulocallaghan For This Useful Post:
    ziex (13th October, 2018)
  11. #7
    fruti's Avatar
    Dec 2009
    Yea, i also talked with developer of DashCoder "Karsten", he also have truble with JC
    I kinda decidet, if DashCoder will figure out i will buy tool from him .... I also talked with Miro from Abritus ... answer was "Not yet"
    Kinda dissapointed for that short answer.
    Regards
  12. #8
    Sep 2009
    Quote Originally Posted by fruti View Post
    Regards
    Dash coder is struggling with JC because dash coder haven't cracked golf 7 yet, they are using smelecom to emulate dash and recalibrate mileage
  13. #9
    fruti's Avatar
    Dec 2009
    Javyb i don't know... DashCoder support Golf 7. Only not JC ...
    Im long time in business and i see alot of stealing solutions all around ....
  14. #10
    mislav88's Avatar
    Mar 2011
    So we wait
    Regards
    what will happen when you reconnect battery? will dash still take km from eeprom or will sync with nec?
  15. #11
    Mar 2015
    Default olf 7 Johnson Control need mileage change
  16. #12
    fruti's Avatar
    Dec 2009
    mislav88 mate you are thinking correctly
    And no ... dash will change back .... this was just a solution for a costumer with certain needs.
  17. #13
    fruti's Avatar
    Dec 2009
    Muratcar mate, is this corected 100% ?
  18. #14
    Dec 2009
    So if you buy a new cluster can you copy data from nec and eeprom and put both data into another cluster so it will show 0 miles, i ask because my customer bought new cluster for skoda octavia jc controls and i set mileage with vcds
  19. #15
    Moderator
    PremierD's Avatar
    Jun 2009
    Eh! it is corrected to what you asked for mate .. standard VDO walking encryption . but I doubt that it applies to your original dump ..
  20. The Following User Says Thank You to PremierD For This Useful Post:
    DashProg (21st November, 2016)
