Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 33
  1. #16
    Jul 2009
    this file cannot open
  2. #17
    Sep 2010
    pass and off file please
  3. #18
    May 2016
    Serbia
    hi friends, can you first check is this read corectly and if you can do immo off on this
  4. #19
    prusony's Avatar
    Nov 2009
    Belarus
    File is corrupted or incorrectly read...
    Non ut edam vivo, sed ut vivam edo.
  5. #20
    May 2016
    Serbia
    try was with minipro but he dont read id of chip. I must see what is problem. Thanks
  6. #21
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by elektronicaar View Post
    Minipro read very well this 29Fxxx. You need to clean all pin
  7. #22
    antwnhszr's Avatar
    Dec 2009
    macedonia is greek....
    hi..what programmer do you use?don't tell me wilem.......
  8. #23
    Vasily.U's Avatar
    Dec 2009
    Belarus Minsk
    Maybe try bootmode? For Infineon C167 processors in Sirius 32 there are two types of connection to the Boot mode. Where on the marking in the LM - it is enough to connect through the resistor with 28 or 104 feet on the ground.Where RM requires a revision on the board ... you need to give a reset signal to the 44th leg flash from the 140th leg infineon, and not from the 141st as in the operating mode.
  9. #24
    Sep 2009
    Everywhere ............................I'm needed
    superpro sp500 is good solution and volta for immo off.tested work 100%
    Money is not everything . . . when you have enough ! ...
  10. The Following User Says Thank You to Topman000 For This Useful Post:
    MOBILTRONIC (19th January, 2020)
  11. #25
    May 2016
    Serbia
    i was try with minipro, this is second ecu that a cant read corectly 29f200. I will try with new flash tomorow to see is this problem in minipro or in me. Maybe i dont clean flash enought. in any case thanks again
  12. #26
    May 2016
    Serbia
    i try with new flash and its working. Can you give me immo off file to write and try with new flash on car. thanks
  13. #27
    Vasily.U's Avatar
    Dec 2009
    Belarus Minsk
    For correct work need original file.
  14. #28
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    make verify id on. this maybe solve your problems (bad id = bad read)
    i have this programer too, working fine with this type flash, but wery important is GOOOOOOOOOOOOD CLEAN PADS i brush pads with sandpaper 1500-2000 grid.
    paper lay on table and with flash brushing
    Sometimes help me little press with finger on flash by reading writing. ewerithing must be good with verify.
    BR
    My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
    My help not for free, press THANKS and REP, for make me HAPPY
    im not using passwords, my work is for this forum and members free
  15. #29
    May 2016
    Serbia
    i try with sandpaper but still not working, and in adapter i broke one leg from chip. i try 239f400 from another ecu and evrerything is ok from id and reading. Like is someting wrong with this flash
  16. #30
    Nov 2015
    World
    Quote Originally Posted by gokart View Post
    Here is the immo off without emulator.
    I need this password.
    You possible help me ?
    I lost my original dump. Tested others and ecu x tcu not comunicate.
    Scenic 1.6 auto-transmission (Sirius32 with CAN)
    Enviado de meu SM-G903M usando o Tapatalk
