Results 1 to 11 of 11
    Sep 2013
    Bulgaria
    Default Bmw E87 A/C problem
    Hi to all!
    I have a problem whit the car from the topic.The airconditioner dosn't start.When i connect the diagnostic <ICOM and LAUNCH>
    i get this error code (E718 Message <status of pressure,refrigerant cirquit,0x2D2)faulty,receiver IHKA,transmiter JBE)
    I mesure the pressure sensor voltage and it have 5v and on the third cable i see 1.73 V so i thing that the sensor is working
    i mesure the signal cable from sensor to the module under the dashboard and the cable is OK!!!
    So if anyone have some ideas i will be very thankful!!!
    Act Tuning's Avatar
    Sep 2016
    Around
    For sure you have a faulty press sensor or wiring problem, do you have Inpa ?? i so check wiring from inpa
    CVN FIX Vag/Bmw
    Tuning Petrol and Diesel
    High Power Maps
    Custom Tuning Stage 3+ Hybrid
    Dsg Tuning
    Sep 2013
    Bulgaria
    No friend i do not have INPA but today i will purchase new sensor to try
    but i already check the wirings and i think that they are OK.Thanks
    Sep 2013
    Bulgaria
    i change the sensor and the same think no Airconditionig when i read datastream i do not see any refrigerant pressure
    Act Tuning's Avatar
    Sep 2016
    Around
    do you have any fault code regardes to a/c ?
    CVN FIX Vag/Bmw
    High Power Maps
    Dsg Tuning
    Sep 2013
    Bulgaria
    yes in IHKA i have these trouble code that i mentioned so i think the problem is in any of these two modules
    Sent from my SM-G920F using Tapatalk
    Act Tuning's Avatar
    Sep 2016
    Around
    send me the codes and vin for the car and itry to help you,
    CVN FIX Vag/Bmw
    High Power Maps
    Dsg Tuning
    Member nacar's Avatar
    Dec 2012
    south america
    hei Rusinov87 have you read engine ecu code issues if you do please post it .
    Sep 2013
    Bulgaria
    DTc(E718) Message <status of pressure,refrigerant cirquit,0x2D2)faulty,receiver IHKA,transmiter JBE)
    WBAUG51080PW50689
    Act Tuning's Avatar
    Sep 2016
    Around
    Quote Originally Posted by Rusinov87 View Post
    WBAUG51080PW50689
    this fault means that you dont have comincation from IHKA to Juncation box, send picture of the fault,
    CVN FIX Vag/Bmw
    High Power Maps
    Dsg Tuning
  11. #11
    Jun 2018
    Sorry to bring this thread alive, but i'm having the same problem. Has anybody fixed this problem? What can it be?
