I am stuck with two H chip to add keys to and would like to whether this dongle can handle the non USA models.
Sent from my SM-G930F using Tapatalk
These dongle was made for Lexus/Toyota Immobilizer System for USA market,tested pass! Are “H” system here in the USA market page 3 (39,59 master 99valet).
scotlock (17th May, 2018), trinicolin (17th May, 2018)
Any chance when will works on Australia model?
And in Europe? nobody thinks in european locksmith.
i think ray-ray gave you all the info you needed to know if it will work in your location
"Our “H” system here in the USA market page 3 (39,59 master 99valet)."
that should mean something i think
im not sure myself sometimes
he speaks a foreign language (computer language)
G CHIP europa cars ok .
h chip not work europa cars
toyota sienna all key lost smart key ok
lexus nx usa smart key all key lost ok
Internet connection still needed to work without?
the update is also missing
At the beginning of 2017, I wrote the software to reset G of the European market, it worked, unfortunately, immo H has requirements higher seed / key level must be given or another sequence of commands .... or the reset option is not implemented in immo (not believe ), in any case, after the correct answer after converting seed / key when I try to give the command reset - immo gives the answer - "busy-repeatRequestt" (KWP2000) bytes - 0x7F .... 0x21 .
Production and development professional IMMOBILIZER/TCU/ESL/ELV/SRS emulators for all brand cars
PORSCHE / FERRARI / MASERATI / LAMBORGHINI - immobilizer solutions
VAG IMMO CALCULATOR SOFTWARE
trinicolin (24th June, 2018)
no idea what that means but sounds cool.........
Check your timing, same commands as the “G” but the calculation is different. Same goes for the smart key here in the USA market.
I wanna ask is rayray reflash eeprom soft inclide on package ?
I know i must purchase the adaprer alone .
Ray ray eeprom flashs only available 3 places i believe
Penloader tools made by him
Autopropad
Seems new penloader type machine from xhorse that was in development
The thanks button is HERE looks like this --->>> THANKS
