Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Oct 2012
    Default Display opel corsa d
    need virgin display thanks.
    Sep 2009
    try this................
  3. The Following User Says Thank You to nikz For This Useful Post:
    shooting (26th June, 2017)
    Oct 2012
    After uploading the display safe flashes and does not want to be introduced to the radio
    shooting's Avatar
    Feb 2010
    WALES
    Quote Originally Posted by tom a4 View Post
    Here is correct unreg for your display
    wbr
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  6. The Following User Says Thank You to shooting For This Useful Post:
    nikz (26th June, 2017)
  7. #5
    epicsabi's Avatar
    Sep 2009
    Budapest
    I can't upload file.
    Try this... maybe will help for you
    000000C0 xx xx xx xx xx xx xx xx xx xx xx A1 00 00 00 00
    000000D0 00 00 xx xx xx xx xx xx xx xx xx xx xx xx xx xx
  8. #6
    Sep 2009
    Quote Originally Posted by shooting View Post
    wbr
    It will not help
    It is necessary to take op-com and marry
  9. #7
    shooting's Avatar
    Feb 2010
    WALES
    Quote Originally Posted by nikz View Post
    It will not help
    Correct, he needs to use Opcom
    wbr
  10. #8
    Oct 2012
    I use opcom and do not run these files, I tried the file without the code does not work
  11. #9
    shooting's Avatar
    Feb 2010
    WALES
    Use my dump and pair with 4660 using OPCOM
    You might need an unregistered CD30 dump too
    wbr
  12. #10
    Oct 2012
    I used your file, the radio I have logged out. And unfortunately it does not work.
  13. #11
    shooting's Avatar
    Feb 2010
    WALES
    You need to post CD30 dump for this to be unregistered too..
    wbr
  14. #12
    Oct 2012
    radio is unregistred
  15. #13
    shooting's Avatar
    Feb 2010
    WALES
    Then you must have Chinese clone not a proper tool
    wbr
  16. #14
    Oct 2012
    original op-com
  17. #15
    shooting's Avatar
    Feb 2010
    WALES
    original op-com
    Then pair with Mid Can and see if the Theft Protection says "ID OK"
    If full it will be ok
    wbr
