Results 1 to 15 of 15
    Dec 2009
    Default ssangyong tivoli mileage
    i need to change mileage tivoli 30549 km to 12000 km
    my chip is D70F3525
    Mar 2017
    Colombia
    Quote Originally Posted by Auto Clinic View Post
    my chip is D70F3525
    hello mate, how did you read this processor?
    D70F3525......
    you can share pin out ... thanks.
    WINNER THE LOSER
    Dec 2009
    Quote Originally Posted by automotrizVIP View Post
    D70F3525......
    You are welcome
    Sent from my SM-G935F using Tapatalk
    Mar 2017
    Colombia
    Mm cg100 error of read, use othres programatory.
    I do not recommend reading it with this equipment
    WINNER THE LOSER
    Dec 2009
    I read and write without problem.
    So I have problem for algorithm dump.
    Sep 2009
    probably need a 2nd dump
    with another mileage.
    Mar 2017
    Colombia
    okay. friend I understand, in that car you should check, this model has a 24c16. localized
    WINNER THE LOSER
    Dec 2009
    Not have
    I changed dump in ecu and then mileage changed to 0 km
    May 2018
    Egypt
    can send me pin out for another proagmmer i have vvdi - upa - xprog or other
    Don't Forget press Thanks & Reputation if helped
    Dec 2009
    Quote Originally Posted by Bastawy View Post
    I do not know about read it via another programmers .
    I read it via CG100 programmer.
    My dump is ok.
  11. #11
    May 2018
    Egypt
    My dump is ok.
    can send me D & P flash
    this D & P Flash but problem
    instrument give me flash light
  12. #12
    letalcrudo's Avatar
    Nov 2015
    Canada
    what tool works by OBD2 ?? any suggestion
  13. #13
    Dr. Zoidberg's Avatar
    Oct 2015
    Talca-Chile.
    Quote Originally Posted by letalcrudo View Post
    enigma, dp4 and many more, do you need read only eeprom data 32kb(I changed 2.), in turn, to read this type of micro 70f3525, it is necessary to make a modification to the upa cable ....
  14. #14
    Feb 2018
    Dec 2009
    Your PCB dash different with me
