Not a software problem only.
Regards
Sima
Head Unit NG4 Becker BE6431 software installation is required.
When the system is switched on, the system starts and after a few seconds the system restarts and reboots, and thus to infinity.
I need the instruction and software for upgrading the device itself. The device has HDD as shown in the pictures!
Regards
Sima
It's not easy but it's possible
the layout is shown in the images
All modules are solder and do not try to remove themCPU board.jpgCPU Board Bottom.jpgPower Supply.jpgRemove metal.jpgus a soldering flux and Rework soldering station
Fix reatarting and rebootingNG4 Restarting.jpg All BGA device and memory hawe silicon termal conductiv rubber onli 1 hawe difrent blue for high temperature.
dis device making the problem rebooting and restarting.
Im fix the problem rebooting now all working for 10
Definitely don't do that.
You don't know what you are doing.
And in desperate attempt to do something,you just make shit on the board...
I know very well what I'm doing and how this device works
and you are trying to make primitive things yourself as an experiment that is very stupid
and you too are immature and in fact you are not the opposite.
Drugim riječima SIMA ne sri matereti
If you know very well,then why rework whole board?Why rework that board anyway?Only because it has BGA elements???
Lets go ahead and drop the vertical board in flux and heat everything???
That shows you don't even have a clue how this device works...
