Results 1 to 7 of 7
    Jun 2016
    Default Skoda Octavia 2012 Ecu
    hi, I have water damage ecu, part num. 03L 906 018 EF
    Boch 0281 016 897
    question: fits ecu with different last words for exemple 03L 906 018 XX ?
  2. The Following User Says Thank You to andrelis398 For This Useful Post:
    Abdssamed1992 (24th March, 2018)
  3. #2
    Feb 2010
    Germany
    In this case I use the good old esitronic. Just enter bosch partnumer and you will see, that this is edc17c46-2.7. Now you can list all bosch numbers, which are edc17c46-2.7. And only this are hardware compatible. But this ecu has OTP. You can not clone directly. You have to decrypt immo data and crypt again to new otp area to get it working. Or take a look at sticker of your ecu. There is a vag hardware partnumber. 03L906018BR. All ecu with this same hardware number should be compatible also.
    Greets MR...
  4. The Following User Says Thank You to brobble For This Useful Post:
    andrelis398 (19th March, 2018)
  5. #3
    Jun 2016
    thanks for idea, I will try to find same partnumber. looks expensive ecu
  6. #4
    Jun 2016
    this one bosh number is different, but vag partnumber is same 03L906018BR, you think ok?
  7. #5
    Nov 2009
    depend is softwer version
    bcm2 elv adapt online offline -echange immodata -clone immodata sinchro bcm elv medc17 edc17 Crafter EZS e EDC17 sinchro -DPF/ EGR/ DTC/ removal/: IMMO ADAPT edc16 EDC17 edc17c64 C74 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
    PCR2.1 FULL CLONE ou adapt, clone all edc17 me17 , etc / dash echange immodata repair immodata add key etc etc
  8. The Following User Says Thank You to koyot For This Useful Post:
  9. #6
    Feb 2010
    Germany
    Yes, this ecu should be OK, but you need to flash it with same software of your old damaged ecu, but same hardware partnumber should be same hardware inside. And esitronic says it an edc17c46-2.7 also, like your damaged ecu.
    Greets MR...
  10. The Following User Says Thank You to brobble For This Useful Post:
  11. #7
    Jun 2016
    i try immo service tool, but blinking on dash active, so need better solution. Please somebody immo off,
  12. The Following User Says Thank You to andrelis398 For This Useful Post:
