Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 48
  1. #16
    May 2018
    Password to the file?
  2. #17
    May 2018
    Here is the flash.
  3. #18
    May 2018
    Good morning everyone. Mr. Vlaki: I am not able to open and extract the content of the file, because it is locked with a password. This is what I requested for in the last post.
  4. #19
    May 2018
    The file worked! My car starts now and doesn't go off again! I truly appreciate this great forum. One of the good things that happened to me is to discover this forum.
    Now, what is left is to recode the ECU. Can someone help me with the engine code for Audi Q7 4.2 V8. The original ECU that came with the car is 4L0 910 560 C.
  5. #20
    May 2018
    The year is 2006
  6. #21
    May 2018
    Hello everyone. I hope everyone is doing fine today. Please can someone help me with immo off for the attached eeprom. It is for 4F191560A.
    Many thanks in adance.
  7. #22
    nickolasd's Avatar
    Nov 2015
    here you go
  8. The Following User Says Thank You to nickolasd For This Useful Post:
    Ter (28th October, 2018)
  9. #23
    May 2018
    Hello everyone. Please is it possible for an immo off Med 9.1 Q7, A6, C6 ECU not to work in another similar car after immo off worked on the original car?
    Why I ask this question is that, I did immo off on the ECU, and it worked fine in Audi Q7, but not in another car. The second car acts as if there is active immo. It starts and goes off.
    So I want to know if I need to immo off the ECU a second time.
    Thank you in advance.
  10. #24
    May 2018
    Default Immo Off for a cloned ECU
    Someone please help me with immo off for this file. It is cloned from a bad 4L0910560C ECU to a 4F1910560A.
    Thanks in advance.
  11. #25
    nickolasd's Avatar
    Nov 2015
    try and report
  12. The Following User Says Thank You to nickolasd For This Useful Post:
    Ter (22nd November, 2018)
  13. #26
    May 2018
    Less than 1 minute ago
    Hello everyone. Hope all are doing fine.
    I will soon give feed back on the immo off file that Nickolasd helped me with.
    Please I have a new question:
    If all keys are lost on a Passat CC 2009, and I do immo off, will car start and run without learning the new key?
    I have tried to learn new key, but my lonsdor k518ise keeps saying no 'key present'.
    Car starts and runs for some seconds, then stalls.
    I will appreciate help grately. Thanks in advance.
  14. #27
    nickolasd's Avatar
    Nov 2015
    engine may run(test it and see what happens) but you will have warning on a dash for key not accepted and steering column locked. make proper key, key should be precoded with data from dump and then programmed, have done them long time ago don't remember details.
  15. The Following User Says Thank You to nickolasd For This Useful Post:
    Ter (25th November, 2018)
  16. #28
    nickolasd's Avatar
    Nov 2015
    i had one immooff ecm tested on 2 different Q7 and it worked in both cases plug and play.
    not every solution works in every case, there are other solutions where flash and eeprom required, we can try it as well.
    Quote Originally Posted by Ter View Post
  17. #29
    May 2018
    You are right sir. It finally worked for me too.
  18. #30
    May 2018
    You are right. It finally worked for me too.
    Quote Originally Posted by nickolasd View Post
