conan981 (18th December, 2020), MikeBaxter (19th July, 2018)
can you help me to DPF off and EGR OFF.
i view this file and with manual procedur i can't make the DPF OFF, infact when i search the string: 00 00 28 44 00 00 43 1C 00 00 43 1C... previuos this string, i think to find a byte cell with the value 01 or 02....but i find 05, why?
Try to help someone.
After that you will be helped!
This is how this forum works.
BR.
Michael
You're right, but I'm an electronic engineering student with little experience in this industry and really want to learn this.
If I find threads where they have problems with electronics I will be happy to share my experience.
Infact i read read and read more threads and some guides because i want to solve fap problem on my dear lancia.
Thanks for your file...now i make pratice with this
on this ecu switch not work, he never work so you no need try
FILE SERVICE
So, is not possible to make fap and egr off? Or there is another method?
Hi, in this RAR are present the original file, read from my lancia delta, and one mod file.
I make it with the help of the guides...i'm not sure it's goo, so what do you think?
thanks a lot for your help
MikeBaxter (5th August, 2018)
Genuine 'WinOLS,MagPro2X17 Master, VagCom-Vcds, Vag Can Pro-Vcp'
And 'Kess-Ktag' Red Pbc Ecu Clone User.
Professional Car Remapper And Ecu Calibration Expert From TURKEY
EDC16C39 are easy ecu, this is done completely wrong
Autotuner user
Kess/Ktag
WinOLS
Can you help me to make a file with no dpf, no egr and 10% more power.
PS this is made by a "professional" chip tuner from poland
MikeBaxter (6th August, 2018)
