Page 40 of 41 FirstFirst ... 3035363738394041 LastLast
Results 586 to 600 of 602
  1. #586
    May 2018
    Could use some help with a flash file for esn 06R0894449 version 2.28 please and thanks in advance
  2. #587
    Jan 2011
    Hello All, does any one know how i can find out what the correct cal/flash file is for a 14 Litre ddec V Ecm. The Unit or engine number is #06R0810259. Also need to know if anyone can share the file/files with me. Would you know if the calibration with Detroit Cal tool is similar to doing it with Insite?
    where can i get a step by step process of calibrating the ecm.
    Thanks in Advance
  3. #588
    DK Veteran Poptest's Avatar
    Sep 2010
    Please share DDEC V 14L 06R0795382 calibration file for DRS.
    Thanks in advance........
  4. #589
    Dec 2018
    Does this program not need kg?
  5. #590
    Aug 2010
    Russia
    Hello, please help with calibration for ESN 06R0456685, thanks!!!
  6. #591
    Feb 2010
    I am looking for a Calibration / Flash File for a Detroit 60 Series Engine
    Engine Serial 06R0361623
    Thanks!
  7. #592
    May 2018
    HI
    hi
    can someone re upload the drs 6 part 2 file or any other version of detroit reprogramming system that dont require a key
    i think the link is damaged
  8. #593
    Feb 2010
    Russia
    Hi guys.
    I need help with series 60 calibration on the
    06R0340511 SK60 engine.
  9. #594
    Jun 2019
    i need the DDRS Software Calibration_Files for these DDEC V engine serial numbers: 06R0874463 & 06R0906083, Horsepower: 550.
    Any response/help would be appreciated.
  10. #595
    Jun 2019
    Hello,
    i also need Detroit DRS Calibration files for 60_Series DDEC V Engines; S/N 06R0874463 & 06R0906083
  11. #596
    Dec 2019
    Hello,
    I"m also need a DRS cal for S60 DDEC 4 S/N 06R0436046 thank you
  12. #597
    Dec 2019
    In search of Cal Files for serial number 06R0563317. This would save ton of time to be able to change original for new application. Thank You
  13. #598
    May 2020
    Thanks Jabkissmya,
    i wanted to find out if there are few things you can help me with kind of new to the DRS software. basically i am in africa and have 60 series ddec 4 and 5 engines 12.7 non egr. how do i reprogram the ecm once i have swapped it from an accident truck to another truck where the ecm is condemned.
  14. #599
    Jul 2018
    Thanks your post
  15. #600
    Nov 2015
    Что именно вы хотите сделать ?
