Results 1 to 7 of 7
    Anzelmas's Avatar
    Nov 2009
    Stockholm, Sweden
    Default MB W211 2003 instrument cluster don't go to sleep
    Hi, m8s!
    This Mercedes is draining battery badly: 1.62A
    By taking out the fuses I located that the main reason is instrument cluster. After disconnecting it the car is eating 0.14A
    Another electricity eater is OCP. After taking out the fuse Nr.9 from the rear SAM the car eats 0.04A
    So the question is: is it possible to fix the original cluster or I must to change it?
    The cluster is working as it must, visually nothing burned or damaged on the PCB, nobody was changing the mileage.
    Cluster VDO A211 540 55 11
    Thank you!
    Nov 2009
    workshop
    is your original cluster?i hade same trouble with different partsnumber odo
    Anzelmas's Avatar
    Nov 2009
    Stockholm, Sweden
    Yes, it's original cluster
    Apr 2010
    Heaven or Hell
    check soldering small group resistor near mcu.
    Mar 2018
    Hello,
    i have same problem with instrument cluster. did anyone find solution?
    thx
    Nov 2009
    repair cluster
    bcm2 elv adapt online offline -echange immodata -clone immodata sinchro bcm elv medc17 edc17 Crafter EZS e EDC17 sinchro -DPF/ EGR/ DTC/ removal/: IMMO ADAPT edc16 EDC17 edc17c64 C74 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
    PCR2.1 FULL CLONE ou adapt, clone all edc17 me17 , etc / dash echange immodata repair immodata add key etc etc
    Oct 2018
    egypt
    i think you should remove diodes from pcb and measure them
