Page 1 of 5 12345 LastLast
Results 1 to 15 of 72
    t77's Avatar
    Poland Lodz
    Default Need pin UEC Astra H
    Hello everybody ,I have UEC from another car and car do not crank, I need pin for this dump.
    UEC eeprom 95040 astra H 1,6 2005year
    Thx for some help
    May 2010
    France Oise
    Hello
    W0L0AHL4848123836
    Pin code 8100
    Bye
    filutek's Avatar
    Aug 2009
    Silesia
    Hi. I need pin for this dump.UEC astra H.TX.
    Member dimss89's Avatar
    Jul 2009
    crete
    Quote Originally Posted by filutek View Post
    your data:
    vin: W0L0AHL4845190490
    pin code: 5440
    BR
    Apr 2010
    Default Hi need pin for astra UEC
    Hello Astra h 2005 doesnt crank or cranks for short impulses, found out that the UEC had been replaced and not programed. Need pin for reset.
    Thanks in advance
    Dec 2009
    Romania
    Default Pin from UEC Astra H 1.7 CDTI
    Please I need PIN to adapt UEC.Thanks!
    Gargamello's Avatar
    Nov 2011
    POLAND
    pin code 9516
    Press " Thanks " button, If my post was helpful
    Gargamello's Avatar
    Nov 2011
    POLAND
    pin code Aivaris 3435
    Apr 2010
    Default Pin code from UEC opel Astra H 2006
    I need help with pin code from UEC astra H.
    Can you help me?
    Thanks in advance
    Griunvaldas's Avatar
    Aug 2010
    DC-DC
    PIN CODE 9388
  11. #11
    Nov 2012
    HI guys,
    Need pin from REC Astra H 2005
  12. #12
    TPS's Avatar
    Jan 2010
    PIN must be 5486
    regards
  13. #13
    Meat-Head's Avatar
    BUMP:-
    For us leechers who are too stupid to decode, where is the code how did you do it?
    Thankssss
  14. The Following User Says Thank You to Meat-Head For This Useful Post:
    grail (3rd July, 2017)
  15. #14
    Jan 2010
    Quote Originally Posted by Meat-Head View Post
    BUMP:-
    Thankssss
    Just worked it out using the other thread m8;
    offset 136
    copy 4 byte -> 77717B65
    xor with 42454353 (BECS)
    =35343836
    translate to ascii=5486
    if some one wants to do a list of vauxhall parts that have pins with some sample dumps and known pins - then I might do a program to get pin - change pin/vin etc when I get the chance
  16. The Following 14 Users Say Thank You to paul_12345 For This Useful Post:
    barho67 (14th February, 2018), bearheroes (18th September, 2014), faze (3rd February, 2020), grail (3rd July, 2017), jack11512 (21st March, 2016), jfiljak (14th December, 2015), Meat-Head (7th September, 2014), pandokrator (2nd June, 2017), pawelelectro (27th December, 2014), ph0en1x (5th August, 2015), tomxx (19th July, 2018), vertyk (8th February, 2019), ypiter (30th May, 2017)
  17. #15
    Meat-Head's Avatar
    Member Pecky who if you stalk has such an item at first he would not release it, now on his site ?80
    but locked to two computers.
    the rec MUST have a photo of the solder points as EEPROM on flip side, need to figer out, same with front one.
