Paddy
thanks for the help mate
I have followed your tut exactly as you have presented it ( fantastic by the way)
now i am stuck on the last part if you can assist.
the last part is the activator
I copy the meta into Albert_s_Easy_Activator
then i double click on Easy Activator.exe
then my trouble begins - this is what it says:
X 75 Unusable to decompress keygen. Run administrator. Error message : path / file accsess error.
I get that message 3 times and then i get another one saying
! runtime error'339' component 'RICHTX32.OCX' or one of its dependencies not correctly registered : a file is missing or invalid.
I have deleted the activator and re- downloaded a fresh copy 4 times but i get the same results.
i have also tried Easyusetools_FOR_Keygen_Mapcheck_Metacheck_ttsyste mpatcher
i was not sure what i was doing with this program but after a bit of trial and error i managed to get the tom tom up and running again but unfortunatly there was no english on there so i could not understand anything
I have since restored the tom tom via tom tom home2 but i still have no english in any of the menu's but the map is in english?
got to use it to-morrow for work and it aint looking good.
any ideas of what i can do now please
Mick
Hi Paddy
I know that you dont want ppl to say thanks but a cant let it go how helpfull you have been
I have got the tom tom up and running again and got the english back
I deleted everything from tom tom again / formated it
and re instaled
still had problems with Albert_s_Easy_Activator as described in my last post? so i had another go with Easyusetools_FOR_Keygen_Mapcheck_Metacheck_ttsyste mpatcher and some how i got it to work
the only thing is now, i have lost my 6 digit poscode finder (i only have 3) and i still do not have truck nav,
at the moment this is the least of my problems because i will be able to use it for work. I will have another go in the week now i have the confidence with you help
so once again many many thanks paddy.
Paddy you are a mine of information
why didn,t I think of that
so now i have everything running I am going to try the truck instalation.
so i assume i have to start the complete prosses from scratch following your tut, but use the navcor for trucks / GO530
I have downloaded this one
http://rapidshare.com/files/18153523..._for_TRUCK.cab
but I keep getting the error mesage when i try to winrar it
! C:\Users\Mick\Desktop\tomtom\navcore_8.070.9589.go x20_for_TRUCK.rar: CRC failed in data.chk. The file is corrupt
! C:\Users\Mick\Desktop\tomtom\navcore_8.070.9589.go x20_for_TRUCK.rar: CRC failed in ttsystem. The file is corrupt
so if this is the correct navcor and it will work with the same map / meta file / keygen etc.... i will just keep my eyes open for another one when it comes available to download.
thanks again you have been a BIG HELP and I hope i havn't been to much of a pain to you
Ok Paddy with your help I / we are almost there!!!!!
Backed up the tom tom GO530 and deleted all files
Downloaded / opened and installed the 2 files (navcore for truck and meta file for map.)
The meta didn't crack the map - it cracked the speed cams but not the map (tried a few times) so i used the original meta that you had suggested and it worked fine.
So now i have a working tom tom with GO910 navcore for truck which allows me to enter all the data for my truck (weight / height / width / axels etc..... but then it says my map does not support data for trucks only car / bike / walk.
I have had a look your maps but i can?t see one that is for UK and supports trucks.
But looking on the positive side I have a bang on up to date tom tom and i have gained a lot of experience with you patients and guidance
Thanks mate very much appreciated
Guinness this is map for truck
here are two kind of navcore for Trucks
Code:http://rapidshare.com/files/181534122/navcore_8.070.9589.gox20_for_TRUCK.rarCode:http://rapidshare.com/files/362824408/NAVCORE_8.391_TRUCK_SE_GO_910.rar
and here map of Europe for Truck
Europe_TRUCK_2GB_840_2554
I never tested these cause I have just only 2GB memory card (needed bigger )Code:http://rapidshare.com/files/367647802/Europe_TRUCK_840_2554.part01.rar http://rapidshare.com/files/367656360/Europe_TRUCK_840_2554.part02.rar http://rapidshare.com/files/367665047/Europe_TRUCK_840_2554.part03.rar http://rapidshare.com/files/367675779/Europe_TRUCK_840_2554.part04.rar http://rapidshare.com/files/367685656/Europe_TRUCK_840_2554.part05.rar http://rapidshare.com/files/367696564/Europe_TRUCK_840_2554.part06.rar http://rapidshare.com/files/367705642/Europe_TRUCK_840_2554.part07.rar http://rapidshare.com/files/367715030/Europe_TRUCK_840_2554.part08.rar http://rapidshare.com/files/367724733/Europe_TRUCK_840_2554.part09.rar http://rapidshare.com/files/367733719/Europe_TRUCK_840_2554.part10.rar
