Page 399 of 462 FirstFirst ... 299349389394395396397398399400401402403404409449 ... LastLast
Results 5,971 to 5,985 of 6917
  1. #5971
    Dec 2016
    Poland
    Quote Originally Posted by garabounga View Post
    En is it solved?
    I will get another tacho tommorow and will post what was wrong, and if it's solved.
  2. #5972
    May 2012
    italia
    [Quote = kubuswujo; 2927537] mi metter? un altro domani tachimetrica e pubblicher? ci? che era sbagliato, e se ? risolto.
    Grazie [/ quote]
    Read wiit carprog A4. Version 4.74 carprog correct change
    1 white
    2 yellow
    3 brown
    4 blue
    5 gray
    6 green
  3. #5973
    Dec 2016
    Hi guys... need help to find which chip is the odometer for this rb8 crypto from lp 570 sts. Thank you
  4. #5974
    honingkoning's Avatar
    Jun 2010
    Dessert
    Quote Originally Posted by Diha76 View Post
    On the other side (need to remove needles) But digi does this by diag.
    Wbr
  5. #5975
    Jul 2013
    I have a clone digiprog 3 i cant find the st19 cable can somebody show a picture of it ?
  6. #5976
    clusters's Avatar
    Mar 2015
    Canada
    Top of the page, search thread option. Use it please.
    If you had you find this.....
    http://www.digital-kaos.co.uk/forums...=1#post1929823
    Please DO NOT PM me asking for help.
    Post in the forum, that is what it is here for.
  7. The Following User Says Thank You to clusters For This Useful Post:
    kronk92 (4th April, 2017)
  8. #5977
    Jul 2013
    Hi can u upload a picture of the cable st19 i have digiprog 3 clone buth i cant the cable thanks
  9. #5978
    Member sonebmw's Avatar
    Jan 2017
    hey guys..I can't change KM to Mile on cluster Land Rover Discovery 2 2003.I was doing correction of mileage and couple of time I was changing the mileage because I tried to make it same (cluster and BCU)! And now I can't to change from Km to mile..
    Any solution ? thank you
    I will add here fille of eeprom 93c56 and file of Mororola MC68HC11PH8 and if someone can tray to do reprogram of those files and make in both on 126 000 miles or something close that number.
    I suspect that eeprom 93c56 file isn't good because of too many failed attempts at changing the mileage.If someone has good file for 93c56 Land Rover Discovery 2...2003year and will share with me I will appreciate it.
    P.S I successfully read and did reprogramming with DigiProg on eeprom and Motorola ( put 126103 on both ) and when I return all back on the car it start out normal and then after two seconds it starts flashing again and I also can't change kilometers to miles.
  10. #5979
    Dec 2016
    Poland
    Quote Originally Posted by yeboah View Post
    In the link that gave You @clusters are the photos of every adapter for DIGI look there and download it !!
  11. #5980
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Default st48 adapter pinout
    digiprog-ST48-pinout.jpgNissan Navara / Pathfinder HCS12 check ST48 adapter pinout mine white and brown pin 7 and 13 was wrong way around opened up db25 conector and soldered correctly works 100% afterwards - see correct pinout
    ST 48 yellow 18 yellow
    green 17 green
    white 7 white
    brown 13 brown
    'If I helped, please click Thanks +Reputation.. !'
  12. The Following User Says Thank You to rtbdiagnostic For This Useful Post:
    memet99600 (20th January, 2017)
  13. #5981
    Feb 2015
    Lincolnshire
    has anyone used digi to do 2013 mercedes a class w176 dash obd?
    Stop getting worried about what could go wrong, and start getting excited about would could go right!
    hmmmmmmm........eeprom
    Digi v4.94, Xtool, R260, R270, Smok, VagProg DataSmart 3+ Smelecom, Autel Maxisys ms908, SpeedFilters
  14. #5982
    Jan 2016
    yes works. (but not sure if all versions work)
    but you need to use a canfilter first
  15. The Following User Says Thank You to mileage1 For This Useful Post:
    honingkoning (22nd January, 2017)
  16. #5983
    Feb 2015
    Lincolnshire
    Quote Originally Posted by mileage1 View Post
    yeah i know i need some filters mate, just wondered if its risky with digi or not haha i dont mind doing the eeprom if its safer
  17. #5984
    Jan 2016
    then best to do eeprom. cluster has to be removed anyway.. (quite easy exctually for this car.)
  18. #5985
    Mar 2015
    itis the st 79
