gokart (29th July, 2017)
@gokart the firmware date from Jul 14 2017 on,the condor fixed the problem,please check the parameter in Self Test,if the date is before this day,update the condor!parameter.jpg
@hipolitogt Please decode the original and new cutted key,and take pictures of them(each one key's decode result interface),to check the cause.
@rob h Dear rob,what's key?which option is used to cut the key?
A reply to Hipolitogts problem.
The Keys va2, va6 and the Renault card blades.
These tips, if not cut like the original, will often wedge and bend the locks first shim.
A selfmade key cut file should fix this for now.
Or a bit of filing, to make the keys tip more steap.
It is clearly visual if you compare the 2 new cut key with the old.
your firmware date is the newest?can I have a look of it?
sorry,deleted
I'll take some pictures today. But there's a new option to copy any key. It will even copy house keys if you can get them in the clamp. It's the bottom option on the left hand side in key duplication. Just pick the style of key cut clamp it in and away it goes. It copy's the exact key shape it doesn't decode a key to bitting number. Make sure your key is clean before you use it. I read a Renault key card and it got the tip entry V a lot better than cutting by code. I never cut a blank as I didn't have a car to try but the picture on the screen looked good.
Sent from my iPad using Tapatalk
Add life to your days not days to your life
P
louis21 (28th July, 2017)
@hipolitogt yes,I saw the difference.I said: "Please decode new cutted key,and take pictures of them(each one key's decode result interface)" , this is to see the the decode situation,then manage to find out the cause,do you still keep the cutted key?thank you for your work!
Yes,purdy's suggestion is a more efficient way to solve the problem if you have the original key
@gokart how about the result?
In the Key Duplication—Universal Type (version 4.0.1 has this option)
It's a efficient way to copy a key.please make sure the key is clean before decoding.
