Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Default chevrolet volt 2014 spare key add
    Hi. Can xtool pad2 add spare key for usa volt 2014
    Key like this.
    sav few videos that possoble add apare without any tools. Just when have ori key.
    Turn ignition on wait till immo light gone. Than put new key turn ignition and it automaticly programs to car.
    http://fkmedia.transponderislan.netd...tik-chv-44.jpg
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    I think XTOOL can
    I add by SKP900 very easy by PIN extract from BCM
    I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
  3. The Following User Says Thank You to CarCity For This Useful Post:
    drugowaz (11th October, 2017)
    drugowaz's Avatar
    Mar 2015
    Lithuania
    how about that trick without tools? by changing ori and spare new key?
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    1 method :
    1. Insert ignition key and turn to the “ON” position. Do not attempt to start the engine. Leave
    the key in the “ON” position for approximately 11 minutes. The security light will be steady
    on or flashing for the 11-minute period. Do not proceed to Step 2 until the security light
    turns off or stops flashing.
    2. Turn the ignition switch to the “OFF” position for 30 seconds.
    3. Turn the ignition switch to the “ON” position as in Step 1 for 11 minutes.
    4. Turn the ignition switch to the “OFF” position for 30 seconds.
    5. Turn the ignition switch to the “ON” position as in Step 1 for 11 minutes for a third time.
    6. Turn the ignition switch to the “OFF” position for 30 seconds for a third time.
    7. Turn the ignition switch to the “ON” position for 30 seconds.
    8. Turn the ignition switch to the “OFF” position.
    9. Attempt to start the engine.
    If the engine starts and runs, the relearn is complete.
    2method :
    1. Turn ignition on.
    2. Attempt to start the engine, and then release the key to the “ON” position.
    3. Observe the “SECURITY” indicator light. After 10 minutes the “SECURITY” indicator light
    will turn off.
    4. Turn ignition to the “OFF” position, and wait 10 seconds.
    5. Attempt to start the engine, and then release the key to the “ON” position.
    6. Observe the “SECURITY” indicator light. After 10 minutes the “SECURITY” indicator light
    will turn off.
    7. Turn ignition to the “OFF” position, and wait 10 seconds.
    8. Attempt to start the engine, and then release the key to the “ON” position.
    9. Observe the “SECURITY” indicator light. After 10 minutes the “SECURITY” indicator light
    will turn off.
    10. Turn ignition to the “OFF” position, and wait 10 seconds.
    11. Vehicle has now learned the new password. Start the engine.
    12. With a scan tool, clear any trouble codes.
    NOTE:
    For most cars, one 10-minute cycle will be enough for the vehicle to learn the new
    password. Perform all 3 cycles if the car will not start after 1 cycle. Most trucks will require all
    3 cycles for learning the password.
    3 method :
    1. Insert a master key (black head) into the ignition switch.
    2. Turn key to the “ON” position without starting the engine. Security light should turn on and
    stay on.
    3. Wait for 10 minutes or until the security light turns off.
    4. Turn key to the “OFF” position for 5 seconds.
    5. Turn key to the “ON” position without starting the engine. Security light should turn on and
    stay on.
    6. Wait for 10 minutes or until the security light turns off.
    7. Turn key to the “OFF” position for 5 seconds.
    8. Turn key to the “ON” position without starting the engine. Security light should turn on and
    stay on.
    9. Wait for 10 minutes or until the security light turns off.
    10. Turn key to the “OFF” position. The key transponder information will be learned on the next
    start cycle.
    11. Start the vehicle. If the vehicle starts and runs normally, the relearn is complete. If additional
    keys need to be relearned:
    12. Turn the key to the “OFF” position.
    13. Insert the next key to be learned. Turn the key to the “ON” position within 10 seconds of
    removing the previously used key.
    14. Wait for security light to turn off. It should happen fairly quickly. You may not notice the
    lamp, as the transponder value will be learned immediately
    15. Repeat steps 12 through 14 for any additional ke
    Good job
  6. The Following 2 Users Say Thank You to CarCity For This Useful Post:
    drugowaz (11th October, 2017), rob h (29th November, 2017)
  7. #5
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Checked car list in pad2 no volt model. Under what other model possible to add key?
  8. #6
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Quote Originally Posted by drugowaz View Post
    Can you give me BCM model and S/N ?
  9. #7
    Sep 2017
    X100 All Keys lost , Run it as Chevy Sonic , Chevy Cruze
    Or like members advised on previous post. Manual procedure The Rule 3 x 10 mins.
    Let us know your results
  10. The Following User Says Thank You to Jobeso66 For This Useful Post:
    drugowaz (12th October, 2017)
  11. #8
    drugowaz's Avatar
    Mar 2015
    Lithuania
    If run as all keys lost. Old original key will be programmed too? As i need just spare
  12. #9
    Sep 2017
    Will be deleted but you can add it on a later procedure
  13. #10
    klaudio's Avatar
    Jul 2016
    Key like this.
    Why not just clone the original key?? That's what I do most of the time and is a lot faster.
    ​Some people just want glory instead of acknowledgment.
    Thanks and reputation is earned, not ask for.
    Have a nice day.
  14. #11
    drugowaz's Avatar
    Mar 2015
    Lithuania
    if clone.remote will not work. who want this type of key without remote
  15. #12
    Oct 2015
    Poland
    Most customers - they want cheap spare key - if remote isn't necessary they don't want to pay for it
  16. #13
    drugowaz's Avatar
    Mar 2015
    Lithuania
    in my country.99% want full key. 1 of 20 choose only service key.
    answer is eeeaaaaa i need to lock door with hand?? eeeaaa neeeaaaa.
  17. The Following User Says Thank You to drugowaz For This Useful Post:
    p1et (23rd October, 2017)
  18. #14
    p1et's Avatar
    Oct 2013
    Hmmm, maybe time to emigrate to Latvia hehe I wish to have customers like that
  19. #15
    drugowaz's Avatar
    Mar 2015
    Lithuania
    I dont say they do full key . Mostly frice is to high. But they rather dont choose do spare key at all . Cars like volt or more expensive from usa they all want full key. This year ive done maybe 2 or 3 keys without remote. All other full keys
