Results 1 to 8 of 8
    imcumen's Avatar
    Feb 2009
    FRANCE
    Default peugeot 308 ecu EDC17C60 dpf adblue
    Hi friends,
    Pleas i need DPF+ADBLEU off
    Tank in advance
    Regards
  2. The Following User Says Thank You to imcumen For This Useful Post:
    Team dz (7th November, 2018)
  3. #2
    pike's Avatar
    Sep 2013
    Hi, can be done.
    imcumen's Avatar
    Feb 2009
    FRANCE
    Quote Originally Posted by pike View Post
    Hi, can be done.
    it's not done yet
    please someone can help me
    Thank
    Best Regards
    Saulius Saulius's Avatar
    Aug 2010
    Herts, UK
    We can help on these edc17c60 ecu's with adblue dpf egr dtc off.
    MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
    We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
  6. #5
    Team dz's Avatar
    Apr 2017
    ALGERIA
    if not solved I have solison this ecu .
    DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etc
    Do not forget to press the button thanks and reputation
    # Algerian #
  7. #6
    Jun 2019
    How did You finally reset the UREA warrning ?
  8. #7
    Feb 2011
    Split
    Quote Originally Posted by FiloFilo View Post
    recode bsi with launch or diagbox
  9. #8
    Team dz's Avatar
    Apr 2017
    ALGERIA
    Je le fais via WinOLS
    Manuellement !
    # Algerian #
