How to flash in vista
hi been reading thow the post. all this problams becose of a image ie !!!gemini image!!! i know of a few forums that has band gemini image from ther bords why has not kaos done it to. all so notice gemini has or had close ther web site down becose of complants they had what they did was unlawfull and whong but as they say what gose around comes around...
Hope someone can help. When connecting the box and jtag cable I get the same kinds of message that everyone else seems to be getting on here,but then I get a long list of error messages with the last 2 lines reading "Flash memory ID's do not match! (should be 0x89 and 0x17). Are you sure this is a dreambox DM7000s. Well I know its a dm500c but what the hell do I do about it!?
Any help would be appreciated.
hello
can i buy a jtag cable or i must make it?
regards shiz
I want to jtag a reciever with this information
tevion
IBM PowerPC IBM39 STB02500, Flash AM29LV160BB.
I need to know please,
has DM500 same CPU and flash??
can I use the jtag program of DM500?
How to work with jtag program
I need jtag pin connection of cabel and hardware(motherborad).
I have a image of motherborad if you need.
any information welcome
thx
regard
I.. unfortunaly I was another one who was bombed by gemini :S
I hope I can recover my clone (I didn't knew it as a clone )
Thanks for Help
well done, my 500s was broken and green light only, this recover my unit. thanks
I would like to know if the jtag files for the philips tuner DM500-S Model would work for the DM500-C with a philip cable tuner?
No, the 'C' uses a 'blimg' (Boot Loader Image file) and the 'S' uses either the dm500_alps.bin or dm500_philips.bin. The loader programs are also different.
'C' uses jtag_windows.exe and 'S' uses JtagDM500.exe.
You may find some of these in the D/L section otherwise use the very popular search engine.
jbvid
wen i try too flash my dm500, it stop after the flash erase
and i try with different computer
wath i can do
I've used the jtagWindow program to reflash the bootloader successfully.
However, while I was using the dreamup to flash the image, the log window showed an message like this:
COM: The hardware detected a break condition.
Then no progress at all.
Is there anything could be wrong?
Thanks a lot.
Forgot to mention one thing.
Don't use Gemini 4.5. The same time bomb inside.
Downloading the guide. Hope it works. DAMN Gemini team!
