Page 4 of 13 FirstFirst 123456789 ... LastLast
Results 46 to 60 of 181
  1. #46
    Jun 2010
    Caribbean
    Quote Originally Posted by teamtuner View Post
    yes is the egr map...and this is your egr info
    can that method of closing the egr be applied to ford edc16c7 as well?
    http://www.digital-kaos.co.uk/forums...-map-addresses
    Denso, Transtron, Hitachi & aftermarket Standalone ECUS
  2. #47
    shooting's Avatar
    Feb 2010
    WALES
    What is the best software to edit dump from Sirius32 ?
    I am new to ECU editing and need guidance
    I have "TunerPro" but do not know how to use it...
    Which one is best and what's the difference? .. "WinOLS" "TunerPro" "RomRaider" "ECM Titanium"
    thank you
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  3. #48
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    Quote Originally Posted by shooting View Post
    thank you
    mmm...
    i think is best the talent of tuner and experience
    the programs make same things...will help you to do a good tuned file or to brocke your car ...
    inside forum:ask me about...i will tell you all that i know
    make me working for you...i will give you my paypal account
    outside forum:
    chiptuning,egr,dpf,add blue,dtc,Eu clones
  4. The Following User Says Thank You to teamtuner For This Useful Post:
    shooting (10th November, 2016)
  5. #49
    shooting's Avatar
    Feb 2010
    WALES
    mmm...
    Everyone has to start somewhere... no???
    wbr
  6. #50
    unnamed11112007's Avatar
    Aug 2015
    Belarus Molodechno
    for me as a beginner ECM Titanium was the first, where I started to understand, everything is intuitive, but it is only for chip tuning, EGR, DPF, swirls, this is not a good solution, here need winols, experience and have head on your shoulders, from side it seems simple, but it is not
    tell me thanks I will be very happy
  7. The Following User Says Thank You to unnamed11112007 For This Useful Post:
    shooting (9th November, 2016)
  8. #51
    Oct 2015
    can some one share some info about bmw dpf off for edc16c31/35?
    From what i've experienced so far there are multiple "things" to "zero" out for a good solution. And i woould like start here a list and i would like that you guys join and correct me if i'm wrong and aprove if i am right.
    1 Mask for blocking and activating regeneration measures (1x1) also known as "dpf switch"
    2 Static Particle Emission Calculation map (8x8)
    3 Stationary Particle Mass Flow map (8x8)
    4 Upper and Lower Hysteresis for Injected Quantity in Regenaration Mode (both are 6x1)
    5 Soot Mass in Particle filter (8x1)
    6 DPF flow related DTC's :
    4CF3 Exhaust Backpressure Sensor
    4166 Particulate Filter system
    4165 and 4166 both for DPF flow resesitence high and low
    4628 DPF System
    4665 DPF Bank 1
    4666 DPF Bank 1
    4667 DPF Bank 1
    480A DPF -Bank 1
    481A DPF -Bank 1
    4618 DPF -Plausibility -Pressure Reference
  9. The Following 5 Users Say Thank You to mircea13 For This Useful Post:
    AGDiag (25th February, 2017), CarCity (2nd December, 2016), donesko (22nd December, 2016), mijatx (14th March, 2017), toshor (20th December, 2016)
  10. #52
    Oct 2015
    and i know there are more switches to turn off and maps to zero out (like post injection maps) for a proper dpf off solution, but i don't know what has to be set to 0 and i will like to learn about this.
  11. The Following User Says Thank You to mircea13 For This Useful Post:
  12. #53
    Jun 2012
    yes ecm titanium is first software for newbie, like me i think. I can do some things on winols but still learning.
  13. #54
    Jul 2013
    Latvia
    Hi guys!
    Wanted to ask - having car VW Passat B6, 2.0tdi - if i will delete TVA does DPF regeneration will work normally?
    Need to delete TVA, but don't want to touch dpf. Thanks in advance!
  14. #55
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    Quote Originally Posted by flashtech View Post
    Hi guys!
    If u make that correctly DPF will be work without any issue.
    All brand FileService - Custom - remapping company
    POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
    | Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
  15. #56
    bobolin4o's Avatar
    Apr 2010
    Bulgaria, V. Tarnovo
    Hi guys!
    TVA... it's the last thing, that i will remove from MY car...
    Just think about - this is the only way to stop the engine when the turbo blows up...
    Regards...
    NO PASSWORDS FOR ANYONE, EXCEPT THE RECIPIENT OF THE FILE !!!
    If your PM box is full, clean it right now...
    Otherwise, your requested file will be deleted... for ever!
  16. The Following 2 Users Say Thank You to bobolin4o For This Useful Post:
    konq100 (19th February, 2017), TPS (8th February, 2017)
  17. #57
    dominik.m's Avatar
    Jun 2009
    POLAND
    bobolin4o He is right. But 5th gear and full press brake too.
  18. #58
    bobolin4o's Avatar
    Apr 2010
    Quote Originally Posted by dominik.m View Post
    What about if the car is with automatic transmission?
    BR!
  19. #59
    dominik.m's Avatar
    Jun 2009
    POLAND
    You are right bobolin4o! Then is problem.
  20. #60
    Dec 2012
    EU
    Quote Originally Posted by bobolin4o View Post
    BR!
    Hehe then you need long straight.fastest SDI on earth.
    Sent from my SM-G935F using Tapatalk
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
  21. The Following 2 Users Say Thank You to gttuning For This Useful Post:
    bobolin4o (24th February, 2017), toms4 (29th June, 2018)
