Page 1 of 2 12 LastLast
Results 1 to 15 of 20
    Dec 2015
    Default audi Q5 read pin code help
    hello is it possible to find Pin code from ecu by file?
    old ecu is dead and i got new i tryed to make immo off but still got safe in dash.
    ecu is edc17cp46
    audi q5 mciro original.rar
    Jul 2016
    Immo 5. Doesnt have pin code if i remember right
    IMMO Version 5
    TPROT_V02.05.0116 TC1767
    CS: 8C5F917FD07FF083811CA0870792A82C
    Oct 2016
    Minsk
    Immo 5+
    Pin 01927
    Porshe & VAG EDC17/ MED17 clone, adaptation, immooff, change Power Class. BCM2 clone, ELV synchonisation, adaptation.
    Dec 2009
    Quote Originally Posted by enagize View Post
    ecu is edc17cp46
    VIN: WAUZZZ8R8BA114567
    CS: 917FD07FF08381
    MAC: 1CA08C5F
    PIN: 01927
    ECU: EDC17C46
    Oct 2016
    Minsk
    Powerclass : 6A
    firestator's Avatar
    Oct 2010
    MINSK
    Here are the most accurate and correct data)
    yugo45's Avatar
    Apr 2010
    On this ECU immo off not possible , Only possible data transfer form original ECU or BCM2.
    Also there is no way to program it with Pin. Pi was used in Immo 3 and some early Immo 4 , late Immo 4 and Immo 5 not going to happen.
    Jul 2016
    Quote Originally Posted by yugo45 View Post
    Yeah, that's what i wrote in the very first post. But if people use the wrong tools they are still able to decode a "pin", a "mac" and even a wrong immo 4 CS ;-)
    Oct 2016
    Minsk
    I can do immoff for Immo 5 without dash error.
  10. The Following User Says Thank You to Medions For This Useful Post:
    doctore (27th May, 2017)
  11. #10
    Nov 2009
    [Quote = yugo45; 3.040.069] In questa immo ECU off non possibile, solo possibile forma di trasferimento dati centralina originale o BCM2.
    Inoltre non v'? alcun modo di programmarlo con il Pin. Pi ? stato utilizzato in Immo 3 e un po 'presto Immo 4, in ritardo Immo 4 e 5 Immo non accadr?. [/ QUOTE]
    I can do it without safe in dash
    bcm2 elv adapt online offline -echange immodata -clone immodata sinchro bcm elv medc17 edc17 Crafter EZS e EDC17 sinchro -DPF/ EGR/ DTC/ removal/: IMMO ADAPT edc16 EDC17 edc17c64 C74 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
    PCR2.1 FULL CLONE ou adapt, clone all edc17 me17 , etc / dash echange immodata repair immodata add key etc etc
  12. The Following User Says Thank You to koyot For This Useful Post:
  13. #11
    Jul 2016
    Quote Originally Posted by Medions View Post
    Quote Originally Posted by koyot View Post
    Then help the guy :-D or is ka-ching involved. Ok, maybe the thanks level needs some improvement :-D
  14. The Following User Says Thank You to steveleo For This Useful Post:
    wokcz (31st May, 2017)
  15. #12
    yugo45's Avatar
    Apr 2010
    UDS protocol ECU is not possible to do Immo off,
    And all Immo 5 ECU has UDS protocol. You can do it in flash and delete code to not display in cluster , but car will start 3-5 times and will not work after that .
    There was few posts about that , where people did it in flash and after 3-45 times start car , it will corrupt eeprom and car not start after that.
    Only data transfer is 100% correct solution.
  16. The Following 2 Users Say Thank You to yugo45 For This Useful Post:
    amigokola (28th May, 2017), steveleo (28th May, 2017)
  17. #13
    Dec 2015
    so know when i have pin cs and mac?
    its not possible to code it with odis og vag?
  18. #14
    alex09's Avatar
    Apr 2013
    Serbia
    Hi yugo45, i think that AVDI can do IMMO OFF on this with no problem. Correct me if i am wrong.
  19. #15
    Jul 2016
    You don't have PIN. Pin 01972 is wrong. This car just doesnt have pin. But i think you can do online coding with it. Or maybe even possible to transfer the CS and config from BCM2 to the ecu. But if you're lucky there will show up some expert here and tell you details.
