Results 1 to 14 of 14
    Dec 2016
    Default BSI, How to exit boot mode
    Hi To All Members,
    I have JC BSI which I corrupt it.( BSI in the car )
    They said the BSI just stop at boot mode and its not corrupt.
    So, the BSI, how to exit from boot mode ?
    (Note: I know how to connect BSI on bench)
    Thanks in advnce.
    Regards.
    brend's Avatar
    Oct 2015
    Same where
    Bult.
    For you give wrong information.
    So......100%correct information its corrupted .
    And I think FVDI killer to do this.
    For restore help, need know flash signature/index .
    NB!!! Don't ask in PM old file password , Im not remember.
    marina_rv's Avatar
    Jul 2010
    Ukraine
    Please send name programmer ???
    Clone or original ???
    Name car, name BSI, send foto + full info.
    Thx.
    please press the little THANKS
    Dec 2016
    Quote Originally Posted by brend View Post
    Bult.
    Yes, the FVDI.
    Regards.
    Dec 2016
    Quote Originally Posted by marina_rv View Post
    Thx.
    Programmer : FVDI
    Make : Clone
    Car : Peugeot 308 VTI, 1600cc, Auto transmission
    BSI : see the picture.
    Problem : When read pin code, the whipper and the head lights are on, then, I switch it off. I took out the whipper fuse (in BSM) I switch it on again. After sometime, pc screen prompt out, "Something is going wrong". Then, off the switch again and switch it on, the whole power system fail ( not even room lights ). So, the BSI corrupted.
    Please help.
    Feb 2010
    In EEP
    Quote Originally Posted by ecupro308 View Post
    Programmer : FVDI
    Make : Clone
    Please help.
    it is normal problem .... read tread about BSI PSA Flash .Sticker not help you BSI have 20th Software version. you need connect in car and in diagnostic log show software signature . 4Bytes . Post here and we will help you.
    Dec 2016
    Hi Vasa,
    I use FVDI. There is NO communication between BSI and FVDI.
    If I change to another BSI, there is communication and show software signature.
    Please advice.
    Regrads.
    Mar 2013
    if bsi no comunication than only way is programmer read write flash but faster way now is used bsi and adapt all on car good luck
    Feb 2010
    In EEP
    go to web site ioterminal he have connection on table try this connection FVDI never kill BSI only boot mode show in abrites folder maybe is backup files isnt good but have software sig. Now i read you second post ... You kill flashing procedur. You need programmer
    Dec 2016
    Quote Originally Posted by electronicservicemate View Post
    Hi electronicservicem,
    Yes. Once can not communicate, should use programmer ( read and write ).
    What programmer should i buy ? ( or do you know the micro controller's name or code )
    Thanks in advance.
    Please advice.
    Regards.
  11. #11
    Dec 2016
    Quote Originally Posted by vasa View Post
    Hi Vasa,
    A lot of information on IOterminal web site. Thanks.
    After go thru the information, the device have to use CAN bus to communicate.
    Since there is no way to communicate to the BSI, i must need programmer, something like Orange, solder some wires to the micro controller, easyCAN4 ( but don't know the real IC's code ).
    I did on Peugeot 307 BSI, to read pin code. It work.( Only on eeprom which is built inside the micro controller ) ( hardware like solder some pins on the pcb, so that can read and write )
    So, i need the programmer.
    Which programmer i should buy ?
    Please advice.
    Regards.
  12. #12
    Dec 2009
    Serbia
    I think it is easiest way to buy used bsi and program to car,
    I have also problem like you but i alive bsi
    I take bsi out off car and conect pins direct on bsi.
    I think it we be good to make backup of eeprom 96128
    I have somwere bsi pinout you can also find here on site
  13. #13
    Dec 2016
    Quote Originally Posted by kizagt View Post
    Hi kzagt,
    Yes, I got the wire diagram on BSI.
    I can run it on bench with Diagbox and FVDI.
    After I run the BSI on the car with FVDI, I corrupt the BSI before I read this web site.
    So, one question to ask, if the BSI work on the bench with FVDI ( read pin code, correct mileage, read Flash ) should no problem, right ?
    Please advice.
    Regards.
  14. #14
    Feb 2010
    In EEP
    Hi kzagt,
    Please advice.
    Regards.
    Not you cant read PIN mileage correction with FVDI on bench (maybe read flash is posible but not trying). In instaling FVDi PSA dabase missing all flash backup. And you will be in same situation as in car BSI in Boot mode .....Wating for good Flash. You need another tool
