hiya i have an old sky dish and want to get a new dish, does anyone know what size i could get for north ireland and does size matter ie if i get to big would that be as back as getting one to small and help would be great thanks all
No its just for the uk at the min
Zone 2 60cm would be better allows for a better rain fade margin
Can anyone help me with the minimum dish size I will need to use 3 LNB's to get Astra 29, Astra 19 and Hotbird in the SE.
Thanks John
does anyone know if it is poss to see the mbc/lbc on badr im in newcastle upon tyne
Just wondering can windy weather make my premium channels scramble I've only got a bog standard sly dish cheers
Depending on your receiver, when signal is lost , it CAN/MAY say 'Scrambled channel'. I know this from my own experiences... Best bet is to goto the settings and get a signal reading when there is bad whether. If there is a 'BER' bar or figure, that should be as close to 0 as possible..
Another way you could check is to find a FTA channel on the same transponder and see whether there is a picture and if there is, look out for pixelations...
Read the Rules here; they apply to EveryOne.
__________________________________________________
DM800s HDOpenbox S10
TM500
DM500s
90cm FortecStar dish
Technomate 2300 motor powered by UsalS
No signal is dish, cable , LNB etc, scrambled means you are for what ever reason not receiving a signal from your CS host. This could be your ISP or a crappy server
Posted using Tapatalk for IPad.
TM500
DM500s
hi everyone im near bolton can i get 28.2/13e/19.2. if i change my dish from s** minidish 45cm to a 60cm dish but has to be fixed with multi lnbs {got boring neighbours and dont want to upset them}
