No, it turn on and stay on, do not blink in any point of the procedure.
Except the component on the picture, should i change the filter with motura? Is it necessary to change the capacitors with other with better quality?
Finally, is it better to use win 7 32bit, instead win 7 64bit? I know that most of th programs run very well on win XP, but these days i suppose that it is not so easy to find the microsoft update files for win XP.
Regards
Alex
alexauto12 (27th November, 2017)
Hi, some one know how to read Delphi ford DCM 3.5 with ktag v 6.70
Hi, from aliexpress or ebay .
Hello guys
Does anyone know, what is the component with mark X14 (something like X) on the ori k-tag and kess boards? (see attached photo)
Does anyone know the full code in order to buy some of them.
thanks in advance
Alex
...self-healing fuse
GM FORD DODGE
tuning - deleting - immo
alexauto12 (11th December, 2017)
TE connectivity miniSMDC014F-2
Hello mates
Can someone that has K-TAG to confirm if the pin (collector) of the BC817 is connected with solder or copper line on the PCB with the self healing fuse X14
(See the attached picture: Red arrow shows the place of the two composnents on the pcb and the blue arrow shows the connection between the to components.
Thanks in advanced
Alex
alexauto12, solved?
Hi alexauto12
I dont know how to upload a foto but on mine V7.020 the X14 and the collector of the BC817 are connected together.
I used it once without done the rework.
I replaced the Power Supply that KTAG came with another 220V/12VDC 1,5A Switching and with ferrite at the end.
You can find it at electronic Stores relative with CCTV equipment.
If you use your workshop Power supply be sure that has filter at the output.
Most of the good switching power supplies have.
Hope i helped.
how to fix a ktag that (ecu not identified)?
Hi all.
I have a problem with my ktag clone. It have software 2.23 and hardware 7.020
I tried to conect in diferent ecus and always give me this message:
"Hardware configuration not support: send the log files to the software provider"
What can I do?
Thanks and regards
Solved. No good conections....
