Didn't you touched any switch by mistake?
Regards,
Hi people,
I tuned citroen berlingo 1600 hdi with edc17c60 ecu
Read boot with ktag, write, and after this cruise control don't work.
Anyone idea? Is there any module damaged like frm module on bmw cars?
Or is possible on software? Corrupted?
Verstuurd vanaf mijn SM-G955F met Tapatalk
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
Regards,
touched IQ x Nm maps¿
In mpc is cruise control??
Is possible?
Next answer
Iq to nm??? Yes i touched, whats wrong with this?
No need to touch this map in edc17c60?
Sedat Garip
Belgium
With Kind Regards,
need with lexia now to be activated after remap, like in renault after remap crusie control not working neede with can clip to be activated again
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
Pfff i dont have this, and customer come back tomorrow morning, no idea what to do..
Is it good idea to try it with ori? Or no waste my time?
Sedat Garip
Belgium
With Kind Regards,
the same
i tried many times and with ori not working again ,you try maybe work in PSA cars ,in renault not work
File Service
What is reason?
Sedat Garip
Belgium
With Kind Regards,
Can you get live data for clutch and brake switch
also try for test 3rd gear like 3000rpm try cruise
what year is car?
do ALL brake lights work?
any fault codes?
it is quite possible that cruise maps are affected by changes in tune file.
I try now write ori back and see if works. We have egr fault with check engine light.
Sedat Garip
Belgium
With Kind Regards,
Sedat, Did you switch off the cruise control and speedlimiter switch before you remove the battery/ecu?
Try write ori back thru obd and switch cruise control on and off @ the end of the writing before you cut off ignition
AUTOTUNER, FLEX ,X17, TRASDATA / NEW GENUIS AND ALIENTECH MASTER OWNER.
FULL SWIFTEC AND EVC RESELLER
FILE SERVICE FROM 8AM - 9PM 7/7
BAPRO 4WD DYNO
Hmm.. I din't tryed, but battery was not disconnected. I write ori back, but same situation.
Sedat Garip
Belgium
With Kind Regards,
If car give dtc, cruise control don't work?
Sedat Garip
Belgium
With Kind Regards,
