I use Carprog.
I use Carprog.
Aliben (1st March, 2018)
replece eeprom from your bsi to new bsi and pin will be the same
Aliben (10th March, 2018)
but i want to know , how to do it without desoldering
is it possible with dashboard vw ? THNAKS
Aliben (11th March, 2018)
hello
to change pin in PSA BSI, i think you have to virgin your eeprom dump then recode with pps/lexia (Coding + Immo adaptation(PIN) + Key learning)
or
You can clone your BSI with smok, avdi or ioterminal (Read FLASH and EEPROM in old bsi , write them in donor) (not all bsi are supported)
sometimes need to key learning after cloning
SMOK is very good tool (you have to spend money for it)
i don't recommend eeprom swapping , works for old bsi but on others strange behavior
For VAG
you can change pin in dash - ECU (adaptation with VCDS Immo2 - Immo3(no sure))
from Immo3+(Dash) / Immo 4(Dash) / Immo 5 (cars with key in BCM2)
you have to adapt with CS , MAC , PIN , POWER CLASS in the donor DASH - ECU (not Immo 5)
VVDI , AVDI , SMOK good tool for the job
hope you find some help in my answer
Best Regards
hi ya on psa we just swap two 95 eprom from old bsi and code bk with car pass
have to be same partnumber letter on the end don't mater
