Results 1 to 10 of 10
    Newbie Gueststar's Avatar
    May 2008
    Default recording to shared folder not recognized...
    Hi,Dreambox 500c Dk_v1 image Setup to record to shared folder but when I try to start recording it shows the following message on the TV screen:
    Record failed due to inaccessable storage.
    Managed to setup recording to NAS drive and this works great but would also
    like to record straight to laptop drive.
    Tried turning the NAS Mount off in the WUI but no joy.
    One thing I have noticed is, in the WUInterface the NAS hardrive is recognized and even shows the capacity of it.
    However when trying to record to laptop shared folder it shows up capacity of drive has: n/a n/a after pressing record and shows up:
    Any ideas would be greatful
    ORY
    Administrator
    Devilfish's Avatar
    Feb 2008
    Is your mount setup ok, i.e. is there a green tick when you look at the settings on the web interface?
    There's a guide here...see if that helps.
    http://www.dreamboxtips.com/how-to-s...ect-recording/
    A NAS drive is Samba (SMBFS) and a PC folder is CIFS, make sure you alter the settings accordingly.
    Post and screenshot of your mount settings from the web interface if you can.
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    May 2008
    Default Screenshots
    Thanks for reply DF,
    The screen shots one with all mounted and the 2nd with just the shared mounted. Managed to share folders in the past..
    Update :
    Smirnoff rules, thanks buddy from your post followed PERRIN11 (he rules to..) he said to create a /movie folder in the /hdd directory, which i duly did and straight away my pc hardrive was recognized.
    thanks for support.
    Last edited by Gueststar; 17th June, 2008 at 11:22 PM. Reason: finally managed to record to pc via shared folder.
    ORY
    Administrator
    Devilfish's Avatar
    Feb 2008
    Hmm...I'll check this out asap and see if I can rectify it.
    V.I.P. Member Curious123's Avatar
    Apr 2008
    I have put 'harddisk' in the server directory and it works for me.
    Sep 2008
    Thank you. Get it.
    Sep 2008
    Quote Originally Posted by Curious123 View Post
    Will this work on a DM 7025?
    Mar 2009
    Default hope..
    Hope this will work for me aswell..
    I have the same problem with my dm500 and dm600
